Reproduction dash pad/panels
Old Jan 11, 2020 | 10:06 AM
JVetthead's Avatar
JVetthead
Default Reproduction dash pad/panels
Anybody used these? Are they padded like original or solid plastic?
Mine are not that great and doing a color change..
Old Jan 11, 2020 | 04:04 PM
7T1vette's Avatar
7T1vette
Anybody used what??? No pics or website on your post...
Old Jan 11, 2020 | 05:43 PM
JVetthead's Avatar
JVetthead
ANY reproduction dash pads, panels.
sold by many, probably one mfg.
https://www.corvettecentral.com/c3-6...2f%3fcount%3d9
Old Jan 14, 2020 | 10:42 AM
JVetthead's Avatar
JVetthead
guess i'll be the guinea pig...
Old Jan 14, 2020 | 11:30 AM
stevedinino's Avatar
stevedinino
I considered buying a dash panel from them a while back (the speedo and tach mounting panel) but mine wasn’t quite bad enough to justify $350.
Let us know how it works out. One more removal/install cycle may be the last go-round for mine. It’s pretty fragile at this point.
Old Jan 14, 2020 | 03:28 PM
62corvette's Avatar
62corvette
I am guessing that you are asking about a ‘77? I had good luck with a black one for my 72.
Old Jan 14, 2020 | 06:09 PM
JVetthead's Avatar
JVetthead
Yep '77, ordered dash pad from Wilcox will report back with quality..
All mine have tabs broken, cracked etc. and need a color change.
Old Jan 15, 2020 | 02:48 PM
7T1vette's Avatar
7T1vette
Tab rebuild and color change are easy, if you a even a little bit "handy"....
Hope all works out for you. It would be good to get your take on the quality and fit of the replacement panels. Please share those thoughts with the Forum when you can.
Old Jan 15, 2020 | 09:19 PM
rgwoehr's Avatar
rgwoehr
I’ve got the aftermarket upper dash pad. The fit isn’t bad, it lines up pretty good with the stock lower dash pads, but the area between the speaker grilles and the windshield warped after being parked in the Texas sun for a year. Also I don’t find the fit of the defroster vent to be as good as the original dash pad. I don’t have a photo of this stuff specifically but you can see some of that in this photo.
Old Jan 16, 2020 | 12:56 AM
TCracingCA's Avatar
TCracingCA
Just don’t forget to remove the made in China-stickers, and you are good. What I don’t know, won’t hurt me!!!!
Old Jan 16, 2020 | 07:48 PM
JVetthead's Avatar
JVetthead
Not gonna go the spray dye route, at least not on dash panels.
Old Jan 16, 2020 | 07:49 PM
JVetthead's Avatar
JVetthead
Ouch
Old Feb 4, 2020 | 10:11 AM
JVetthead's Avatar
JVetthead
finally received dash pad. It is made by Corvette America and I am pleased with the quality, it looks and feels like original and has that new car plastic smell!
Have not cked fit yet...
Old Feb 5, 2020 | 09:41 AM
Eliredandblack's Avatar
Eliredandblack
Remember that you may need to “warm” the middle of the dash pad to install it on your car. The new plastic may be more pliable than the original, but you should still go slow. On my 73, I used a heating pad to warm the center of the pad when removing and then again when reinstalling.
To Reproduction dash pad/panels
