L48 toast? Need advice!
Old Nov 19, 2002 | 02:04 PM
Captain_Kaboom's Avatar
Captain_Kaboom
Default Re: L48 toast? Need advice! (Neo Fender)
Just looking at some crate engines that are 4-bolts, and wondering if I they will work as a replacement for my L48, which I hear is a 2-bolt. Would this be a problem?
Thanks!
Old Nov 19, 2002 | 02:11 PM
Neo Fender's Avatar
Neo Fender
Default Re: L48 toast? Need advice! (Captain_Kaboom)
Thanks!
No. BASICALLY, all Small Block Chevy engines from 1955 to 1986? are externally the same (before anyone jumps in, yeah I know, '55s didn't have oil filter bosses, 400s have siamesed cylinder walls, yada yada).
For your requirements, whether an engine has 2-bolt or 4-bolt main bearing caps will not cause problems. The caps are within the oil pan.
Old Nov 19, 2002 | 02:42 PM
Alwyn678's Avatar
Alwyn678
Hey Capt. I sent you an E-mail about Jerry ....He is a service manager at All Star Jeep Chrysler.....He said he woulkd be glad to speak with you about it and quote you a price up front :cheers:
Old Nov 19, 2002 | 02:54 PM
jackson's Avatar
jackson
http://sallee-chevrolet.com/ChevySma...8s/gen350.html
Brand New GM Goodwrench LONG block 350ci with 3yr/50,000m Goodwrench warranty ... 4-bolt main, about 250hp ... all for under $1600.
Old Nov 19, 2002 | 02:57 PM
Neo Fender's Avatar
Neo Fender
Default Re: L48 toast? Need advice! (jackson)
Jackson,
I too thought that was a good bang-for-the buck engine but I believe there are a few forum members here that own them and they've been less than pleased.
Old Nov 19, 2002 | 03:13 PM
jackson's Avatar
jackson
Why are they displeased?... if it's cuz it won't run with a zz4 ...then get a zz4. BTW, this motor specs out virtually same as a factory L48 ... even the small cam. If they're displeased with serviceablity .... there's that long goodwrench warranty that I've not seen duplicated. If I wanted a replacement for L48 (not an upgrade) I wouldn't hesitate to go with this one.
Old Nov 19, 2002 | 03:30 PM
Neo Fender's Avatar
Neo Fender
I agree for the most part but supposedly it's a great block filled with not-so-great parts. They are supposedly assembled in Mexico if that means anything. Leaks are a problem.
It's a good warranty but only if it can be backed up. If there was ever a failure with it (or any engine) it would be up to the owner to prove that there was a defect in material or workmanship. The manufacturer could easily claim that the engine was abused, raced, neglected or not properly serviced by the owner and in turn, not honor a warranty claim. It's the owner's fight.
I would consider this engine if I ever needed a replacement but I would like to hear from more people who've actually owned it.
Old Nov 19, 2002 | 03:48 PM
jackson's Avatar
jackson
I'd also like to hear from others that've got one. Little doubt in my mind that nearly all domestic cars/trucks/motors have some roots of production in Mexico. Any company's warranty could be denied for any reason ... regardless if grounded in fact or not. A loose rod bolt is a loose rod bolt ... whether overlooked in US or Mexico or Canada or Europe. BTW, I'm neither hispanic nor a proponent of offshore (or sob) stuff ... it's just that (sadly) Mexican production is a fact of life.
Old Nov 19, 2002 | 04:17 PM
Captain_Kaboom
Yeah I found a new long block from a Chevy dealer up the road for $1550; sounds like it is the same thing with the 3yr/50,000 mi warranty. It's either get that new block, or buy a rebuilt one (maybe from http://www.rebuiltcarengines.com). The rebuild has a warranty, but there is one that is already built out to 275hp for the same money.
Old Nov 19, 2002 | 08:34 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Captain...
Do yourself a favor & at least go with a 4-bolt main block if you are going the route of ripping out this motor and replace it. And I think you will be sorely disappointed just going to 275HP. Save up a few more bucks and go with 300 to 350HP. That's nothing radical at all and a better resale value in the future.
Just my 2 cents from an owner of a '74 L-48(195HP) that sounds great, but couldn't outrun a midget on stilts. :)
Old Nov 19, 2002 | 11:00 PM
Captain_Kaboom
Default Re: L48 toast? Need advice! (bgrice)
I'm thinkin about it. Brain says yes, wallet says no.
