Brakes won’t work
Old Feb 8, 2020 | 09:52 PM
Gabriel Vianna's Avatar
Gabriel Vianna
Default Brakes won’t work
Ok, so I’ve finally been able to install a new brake caliper in my car as the old right passenger caliper was leaking. The master cylinder was also rusty so it was replaced. After bleeding the brakes the car still wouldn’t brake properly. I have to fully depress the pedal in order to stop and if I brake hard the wheels lock up very fast. Also the pedal kind of pushes back against my foot. There isn’t much resistance on the brake pedal when the car is on. It feels normal when the car is off. I don’t know why the brakes won’t work, I’m going to have a friend of mine who has more experience bleed the brakes again and I hope that might fix it. Im also worried it might be the proportioning valve. I don’t know a lot about brakes so I was hoping someone with more experience could help me out. My car is a 71 with power discs on all wheels. Also the new caliper I bought is rubbing on the wheel. I have American racing wheels.
Old Feb 8, 2020 | 10:13 PM
MelWff's Avatar
MelWff
Did the old caliper rub the wheel?
if not either the caliper is not installed correctly, the wheel is not installed correctly or the wheels are not intended for your car.
When you replaced the caliper, did the master cylinder completely empty?
What sequence did you bleed the brakes and what method?
Old Feb 8, 2020 | 10:35 PM
Gabriel Vianna
The old caliper never rubbed. The wheel might be able to be spaced with washers as there is no way of installing it or the caliper in a different wheel. I’ll probably sand the caliper down. I had emptied the old master cylinder and then reinstalled it in the car. I bench bled the new one and properly bled the brakes with a high vacuum, the gauge was at 5. I can try and bleed the brakes by pressing the pedal. Should I bench bleed the MC again?
Old Feb 9, 2020 | 01:32 AM
robertwg's Avatar
robertwg
If brakes are locking up to quick it sounds like you may have installed wrong bore size master cylinder. There is a difference between manual brake master cylinders and power brake masters
Old Feb 9, 2020 | 08:00 AM
interpon's Avatar
interpon
Please don’t sand them down..send some pics maybe that will give better isea whats going on
Old Feb 9, 2020 | 11:18 AM
Gabriel Vianna
Yes I am well aware, I purchased an aluminum MC from pirate jack racing which is a GM universal unit. I called them and asked if I needed to order a PWR version but they said it worked with both. There is an adapter which I will include pictures of, that came in the box. I tried installing it but it didn’t work. Also my brakes don’t lock up quick they lock up when the pedal is on the floor with more pressure being applied to it.
Old Feb 9, 2020 | 11:32 AM
Gabriel Vianna
Caliper after rubbing with the wheel
Burs on the wheel from rubbing with the caliper
Old Feb 9, 2020 | 11:43 AM
HeadsU.P.'s Avatar
HeadsU.P.
Ahhh. There's the problem. After market stuff that is suppose to fit. Asterisk says: but not C3 Vettes.
I know you don't want to hear this, but go back to Delco Remy. (rebuilt) on the master & calipers. They are specific fit, where as some Delcos Chevy parts fit Chevelles, Novas, Impallas, etc. Master cylinders are very-very specific what they fit in the C3 world. Its all about the booster rod gap and the MC piston inside.
And caliper fitment is very specific too. Front or back. Left or right. Its all about the bleeder screw location.
Proportioning Valves seldom fail. There not mush inside them to go wrong so I don't that is an issue.
Take a look at my profile, photo album, bleeding brakes for info.
Old Feb 9, 2020 | 11:54 AM
Gabriel Vianna
I bought the correct caliper and it’s a new casting so I wouldn’t mind shaving of 1/32 of metal just so my wheels will fit. I’ve seen other threads that spoke about the pirate jack racing MC and how it worked in their car but I’m kinda skeptical about it. My old MC still works but is very rusty. It also developed the same problem that the car currently has. The brakes are soft until the very end and I can go over 30mph or else the car won’t stop properly
Old Feb 9, 2020 | 11:56 AM
robertwg's Avatar
robertwg
amen headsu.p.
Old Feb 9, 2020 | 12:18 PM
Gabriel Vianna
I’ll try bleeding the brakes one more time and then I’ll give you an update on the situation. One more thing, I forgot to put the cover on the MC and when I pressed the brake pedal in a good amount of fluid shot up and out of the master cylinder. Is that normal or should the fluid be going into the brake calipers and some sort of pressure relief systems is not allowing that to happen?
Old Feb 9, 2020 | 12:26 PM
Antz81's Avatar
Antz81
Vacuum bleeding doesn't work properly on c3s
bleed again using the pedal.
Old Feb 9, 2020 | 12:31 PM
Gabriel Vianna
Thanks, I make sure to try that
Old Feb 10, 2020 | 06:32 PM
HeadsU.P.'s Avatar
HeadsU.P.
You have it backwards. Pedal method does not work well. It trips the Proportioning Valve activating the brake warning light.
The pedal travel distance is shorter than most cars so it takes a longer period to flush the air out.
I have had decent luck with the vacuum method. Motive Pressure is better and some prefer gravity bleed. Why? You never touch the pedal.
And for what its worth, when using a vacuum pump tool, don't open the bleeders too far. Air will leak past the threads. Open just enough to get flow.
Old Feb 10, 2020 | 06:35 PM
Antz81's Avatar
Antz81
You are the first person I've ever heard of to have success with vacuum.
I also prefer the motive bleeder, forgot to mention it in my last post.
Old Feb 10, 2020 | 06:43 PM
Fredtoo's Avatar
Fredtoo
The problem with vacuum bleeding is that the calipers have lip seals.
Lip seals seal very well in one direction, but not the other.
These can act as a valve to let air get sucked past the lip.
Old Feb 11, 2020 | 09:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Gravity bleed the brakes........do one at a time starting with the right rear........pop a cold beverage and wait for it.......I have a Roku in the garage and recently sat and watched a movie while gravity bleeding a 71' Demon that I put a Wilwood disc brake kit on.......all new lines, pop valve, master, etc........took three hours all the way around. Once all of the bleeders were closed.....perfect pedal and stopping. Hell, my buddy in Michigan replaced his front calipers on a 2010 Silverado....ask me how to bleed it and told him gravity.......worked for him on a modern ABS equipped truck!
Try it....it just works.....and no special tools necessary! Hydraulic fluid will find its path and take all of the air with it........in fact, most hydraulic equipment is bled this way.
Jebby
To Brakes won’t work
