Which Bolts Need Thread Locking Compound?
Old Feb 11, 2020 | 08:17 PM
DC3's Avatar
DC3
Default Which Bolts Need Thread Locking Compound?
Just recently began the process of an engine/transmission swap in my '73. Also plan to swap the gas tank and pull the differential to have Gary R rebuild it for me.
Curious as to what the gurus think regarding which bolts should be installed with thread locker. Is there any consensus as to which type of bolts need thread locker and which do not on our C3s?
Bolts such as:
Transmission bellhousing to engine block.
Transmission torque converter to flexplate.
Transmission cross member.
Header bolts.
Rear spring bolts.
Differential mounting bolts.
Front drive accessories.
Others?
Also, how do torque specs change, if at all, when using thread locker?
Do any of the answers change when bolting into aluminum (i.e. cylinder heads, etc)?
Thanks,
DC
Old Feb 11, 2020 | 09:09 PM
bashcraft's Avatar
bashcraft
None of them need thread locker if they're torqued properly.
Old Feb 11, 2020 | 09:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
Even an over torqued fastener can back out. Thread-locker was not invented for people with weak arms but rather a safety margin of potential failure.
Any place where harmonics are involved should receive a drop:
Flexplates / Flywheels
Torque Converter bolts.
Differential Mounting bolts.
Spring bolts should be locknuts.
Header bolts, you could use anti-seize. Retorque after 3-4 heat cycles.
Old Feb 11, 2020 | 09:50 PM
lars's Avatar
lars
Torque converter to flexplate.
Lars
Old Feb 11, 2020 | 10:45 PM
bashcraft's Avatar
bashcraft
An over torqued fastener will break.
Old Feb 12, 2020 | 02:04 AM
revitup's Avatar
revitup
Good idea to replace any old/original split lock washers when you get access during a repair.
Old Feb 12, 2020 | 11:49 AM
DC3's Avatar
DC3
I used to believe that too until I started coming across loose fasteners that I knew were torqued properly. I also realized that every modern vehicle I've owned has come from the factory with at least some fasteners installed with thread locking compound. It would be interesting to find out what today's factory engineers would do if given the task to re-spec all fasteners on our C3s.
I certainly trust advice from guys like Lars who disassembled cars on a regular basis.
DC
Old Feb 12, 2020 | 11:52 AM
DC3's Avatar
DC3
I was always taught to replace any split washer that remained flat and also those that did not spring back to original configuration. If they spring back to normal, supposedly they are okay for reuse. Do you know of any technical articles that support tossing them after one use?
DC
Old Feb 12, 2020 | 12:38 PM
revitup's Avatar
revitup
DC
Sorry, I wasn't implying that all split lock washers should be replaced after one use but if it's been in use for long, 40 years or so for instance, I'd just replace it. Pretty tough to judge if they are still effective and retaining their original spring rate just by looking.
Old Feb 12, 2020 | 12:43 PM
GTR1999's Avatar
GTR1999
Something to think about. Back in 1976 GM did away with the hardened lockwashers and shoulder bolts used for the vette ring gear. They replaced them with flanged head bolts,no thread locker. A huge amount of them backed out in use, properly torqued.
When you are thinking about the use of Loctite be sure to understand the properties of the metal you want to retain. Brass, SS, plated metals I use the correct primer for bonding otherwise it won't work. I took a grade 8 cad plated 3/8-16 nut and used #271 Loctite on it then screwed it onto a steel socket head cap screw and waited 24+ hours in 68*F temps, then tried to break the bond. It broke free without much effort. At the same time I just finished up a polished and tuned posi that I installed a new Tom's 373 gear on. I had cleaned the holes in the gear and the ARP bolts with Acetone, installed the bolts with the same #271 Loctite that failed on the bolt test. This sat in the same room and temp for 24+ hours. I went to back off the bolts and they were solid, they broke the sears 7/16 box wrench in the process.
Old Feb 12, 2020 | 06:31 PM
DC3's Avatar
DC3
Thanks Gary,
Appreciate the input.
DC
Old Feb 13, 2020 | 05:33 AM
derekderek's Avatar
derekderek
Loctite bolts that are moving in use.
Old Feb 13, 2020 | 09:16 AM
jim-81's Avatar
jim-81
that's a good rule of thumb
Old Feb 13, 2020 | 09:20 AM
SH-60B's Avatar
SH-60B
Bolts such as:
Header bolts.
Rear spring bolts.
Others?
Thanks,
DC
I anti size almost all of it. Definitely everything screwing into aluminum.50K to 70 K on brake fasteners, nothing came loose, and I'm able to get it out the next time.
Old Feb 13, 2020 | 09:53 AM
pltmgr's Avatar
pltmgr
Loose bolts? Its usually impact wrenches, breaker bars, busted bolts, and gallons of Kroil/PB Blaster for me.
To Which Bolts Need Thread Locking Compound?
