Help with 1972 LT-1 ignition
Old Feb 21, 2020 | 12:50 PM
CV71H's Avatar
CV71H
Hi guys,
we tried out best today, but it wasn't good enough .
So, we did the following:
1. checked the OT moarking using a dial gauge with spark plug hole adapter. Showed the OT marking to be in the right ball park, but I'm not convinced this is accurate enough. I have a piston stopper, but can't find it ATM. Also, how do you realistically measure between the two "new" OT markings on the balancer with the engine in the car?
2. reset the distributor to "Corvette Specs" using Lars' papers
3. put the old cap and rotor back on just to exclude those
4. put the old coil from my 71 in just to exclude that
5. measured the spark leads - they're between 12kOhm (short leads) and 22kOhm long leads, so should be OK.
6. Plugs are new
What's the car do? Well, it kind of starts but makes me wonder if it's running on all cylinders... Won't idle below 1500rpm or so. When I try adjusting the timing even ever so slightly towards late it does it's best to impersonate a flame eater!
What now? I still think the OT marking may be off, but other than that I'm stumped!
Cheers
Es
Old Feb 21, 2020 | 04:55 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Two questions:
  1. Does or did the LT-1 have Transistor ignition originally? They need a specific coil. And the modules can fail.
  2. Are you sure you are on the firing stroke and not 180 degrees out? The distributor only turns once for every two crankshaft turns.
Old Feb 21, 2020 | 06:01 PM
CV71H's Avatar
CV71H
Hi Leigh,
the car is a points car!
I'm 100% sure we're on the compression stroke - I don't think the engine would run at all if we were off by 360°°
Cheers
Es
Old Feb 22, 2020 | 04:49 AM
Chuck72's Avatar
Chuck72
Two thoughts:
1) Has anybody used ether starting spray? One word, DON'T!
2) An engine that displays abnormal results from normal adjustments needs to be examined for the possibility that the timing chain, (as previously mentioned), has jumped a tooth, which usually occurs as the engine is turned off. When this happens, a person can get it to run, but it'll run really poorly.
Best guess.
Old Feb 22, 2020 | 05:45 AM
Chuck72's Avatar
Chuck72
OP, another problem that causes symptoms like you describe in your initial post, is water, moisture, inside the distributor cap, usually occurs when a warm engine is washed.
Old Feb 22, 2020 | 06:05 AM
CV71H's Avatar
CV71H
No start spray used or engine washing done!
What's an easy way of checking if the timing chain has jumped? I think it's unlikely though, as the engine was running OK prior to starting working on it....
I've found my piston stopper btw ;-)
Cheers
Es
Old Feb 22, 2020 | 10:59 AM
lars's Avatar
lars
You can check to see if the cam is clocked correctly (jumped timing chain) as follows:
1.---Pull off the driver's side valve cover. Turn the engine to TDC, and check #1 cylinder's valves. If both of them are closed, you are at the ignition point. Turn the engine over 1 time, back to TDC, and both valves should be off the seat.
2.---Check the height from the top of the retainer to the spring seat, first on the intake, then on the exhaust. I recommend something like a Machinist's 6" steel rule. Make sure you write them down, because you need to see which one is closest to the head.
3.---If the cam is in the engine right (timing chain not jumped), the intake retainer will be .030" to .060" CLOSER to the head than the exhaust retainer is. If the cam is retarded, the exhaust will be closer.
Lars
Old Feb 22, 2020 | 11:13 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Lars
Absolutely awesome check! Never though of this in all of my years......!
Jebby
Old Feb 23, 2020 | 03:37 PM
Elcransonator's Avatar
Elcransonator
Ok everyone, I've been following along here/only had my '73 about 3 months. So I got my new digital timing light with advance/retard buttons + dwell function today. I tweaked the dwell to 30 then checked advance and found I'm at 10 degrees BTDC @ 700 ish rpms with vacuum line off distributor and plugged. The bad news is I plugged the vacuum line back on there/no change whatsoever. Then I took vac line back off and rev'ed it up and found I only get to 22 degrees adv @ 3000 rpms, also not good. Put vac line back on, same exact deal, 22 degrees adv at 3000 rpms. So I guess that means I got a vacuum problem? The question I guess is where do I start? Don't know if this matters but my headlights work fine, so there is vacuum under there somewhere.
Old Feb 23, 2020 | 03:41 PM
lars's Avatar
lars
Are you attaching the vacuum advance to a ported vacuum port on the carb, or are you hooking it up to a manifold vacuum port on the carb? If you're using ported, switch to manifold. If you're using manifold vacuum, you have a bad vacuum advance control unit - replace it. Then fix your timing so you get 36 total.
Lars
Old Feb 23, 2020 | 03:49 PM
Mrvettenick's Avatar
Mrvettenick
If you can get your hands on a mityvac, hook it up to the advance unit to see if the rod even moves. If it does, then make sure you have it hooked up to the right place, Don't you have the under hood vacuum decal?
Old Feb 23, 2020 | 04:38 PM
lars's Avatar
lars
Don't use the underhood vacuum decal hose routing unless you need to pass an emissions test. It will have you using ported vacuum. Do not use ported vacuum - use a manifold vacuum source on the carb.
Lars
Old Feb 23, 2020 | 04:48 PM
  #33
Elcransonator
Lars
I haven't changed a thing since I got the car/runs fine; I'm just kinda **** about checking stuff/maintenance. So the answer is I'm not sure what it goes to but I have a picture. It's a little round gizmo on the manifold with electrical plug going into it from the firewall side. Vacuum line is in my hand, distributor is to left, and vacuum line goes into that device at the 3 o'clock position/straight out to the right (hidden by bigger hose in foreground)
Old Feb 23, 2020 | 05:01 PM
  #34
lars's Avatar
lars
Plug your distributor vacuum advance directly into a manifold vacuum source on the carb.
Lars
  #35
Mrvettenick
That large diaphragm is the EGR valve. If you're happy with the car, keep it stock. That's why I recommended following the label. The label should tell you what the solenoid is.You decide.
Old Feb 23, 2020 | 05:27 PM
  #36
Elcransonator
Lars
Not sure which one of those on the carb is right one, but I can probably figure it out.
Now that I've had a moment to ponder this, I recall the guy I bought the car from mentioning that he had an electronic ignition type distributor put on there (by whom I have no idea, he was definitely not a wrench type dude at all). He said it didn't work right so he had original distributor put back in/ran fine after that. I bet that's when the vacuum lines got shuffled, at least that's my guess.
Old Feb 23, 2020 | 05:40 PM
  #37
Elcransonator
Lars
Where exactly is the "underhood vacuum decal hose routing?" Only sticker I see under there is a placard (vehicle emission control information) that is on flat spot right behind brake booster at left rear corner of engine bay. It has the timing, dwell, advance info for manual/automatic etc etc, but nothing like a hose diagram.
To Help with 1972 LT-1 ignition
Old Feb 25, 2020 | 04:04 PM
  #38
CV71H's Avatar
CV71H
Hi Guys,
We had another go today....
Checked TDC with a piston stop. TDC was indeed out (after TDC) by over an inch on the circumference of the damper!
We drew a new TDC marking an set about adjusting the ignition again. Started fine an ran for long enough to adjust to 36 max BTDC.
However, once it got a bit warm, it started running rough again spitting through the exhaust.. I then noticed that header #3 was glowing red......
We pulled the valve covers, and I think the valve lash is much too tight, causing fuel to be burned in the exhaust. We couldn't measure the lash stone cold, but warm and hot we had less then 0.004" (yes, two zeros behind the .) lash....
Correct lash would be 0.024 and 0.026 intake and exhaust, no?
Re the Holley: we fitted new float valves, and there's now fuel dripping from the annulars at idle. That's not correct surely?
We'll have another go at the weekend I think....
Cheers
Es
Old Feb 25, 2020 | 04:24 PM
  #39
lars's Avatar
lars
You're right. 1972 did not have the vacuum hose routing on the emissions decal. Here is the 1972 LT1 emissions decal - there was no vacuum hose routing on any engine compartment decal in 1972:
First year for the hose routing decal was 1979 (separate decal). Beginning in 1980, the hose routing was part of the emissions decal.
1979 Emissions & hose routing decals:
1980+ decal after the 2 separate decals were combined into one:
No that's not right - that's a bad thing. You do not have bowl fuel level control, and it needs to be fixed.
Lars
Old Feb 25, 2020 | 04:48 PM
  #40
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yes.... .024 and .026 is a good baseline.
If you are leaking through the boosters after float is installed then the metering block gasket is bad....did you reuse it? Did you reset both floats for dribble out of the sight plug?
You are definitely on the right track now....
Replace that damper ASAP.
Jebby
