Help with 1972 LT-1 ignition
Old Feb 18, 2020 | 12:37 PM
CV71H's Avatar
CV71H
Default Help with 1972 LT-1 ignition
Hi!
And friend and I are trying to fix the ignition on his 1972 LT-1, but are having no luck at all...
When the engine eventually starts, it spits violently through the carb and won't idle or run smoothly.
I've managed to set the dwell angle at 29-30°, but setting the timing is proving massively difficult.
We can get the engine started with the distributor turned more or less all the way anti-clockwise (as seen from above), but as soon as I start retarding it (by turning clockwise), the engine starts spitting flames through the carb.
A visual comparison with my 1971 L48 shows that the distributor on the LT-1 is turned much further anti-clockwise than mine, with the inspection window for the points pointing almost straight forward towards the manifold, whereas on my 71 it's pointing more or less towards the front right wheel.
Is there a way the distributor could have been mounted wrong? We haven't checked OT in relation to the marking on the balancer, but will try so with a dial gauge on spark plug hole #6 (seems easier to get at, and should have the distributor finger pointing 180° from #1 if I'm not mistaken).
Any suggestions would be most welcome!
Cheers
Es
Old Feb 18, 2020 | 03:23 PM
Mrvettenick's Avatar
Mrvettenick
How did this run before you touched it? Yes, it is possible to be like a gear tooth off. I would bring the damper to TDC for cyl #1, then look to see where the rotor is pointing., just make sure the rocker arms are in the fully closed position, If they're not, you're probably TDC for #6, then just rotate the crank one more time. The other possibility is the timing chain.has jumped, throwing the cam. crank timing off.
If it's just the rotor that's off, you might have to turn the oil pump shaft to get it to line up. When removing or installing the distributor. the distributor shaft will rotate a little when it meshes with the cam gear. So you may have to try it a few times to get it to line up. Also, when you do set the timing, make sure the vacuum advance is disconnected and the hose is plugged.
Based on your post, it looks like the distributor is out of sync with the engine. That adjustment window should face the right front tire.
Good luck.
Old Feb 18, 2020 | 03:45 PM
jackson's Avatar
jackson
OP CV71H
First ...
... Verify the outer inertia ring on your damper (where the timing groove is) has not slipped ... rubber degrades over time & they do slip.
Bring # 1 piston to True TDC on compression stroke (verify that via spark plug hole) ... and verify that coincides with Zero Groove & Zero tab.
Zero Groove on damper must be aligned w/ Zero on timing tab ... if all that checks, then proceed with your distributor.
Old Feb 18, 2020 | 03:46 PM
CV71H's Avatar
CV71H
Thanks!
it ran OK - except for the carburettor, which we set out to rectify.
We swapped the distributor cap and rotor, points and plugs. I mad the mistake of not noting the ignition timing before attempting to adjust it - stupid me!
How far out can the distributor shaft be? Doesn't it have a groove in it so that it can only go in one way?
Cheers
Es
Old Feb 18, 2020 | 03:58 PM
jackson's Avatar
jackson
First, Verify damper's Not slipped. Maybe it slipped, may be not ,.. you cannot KNOW unless you Verify.
As mentioned in post # 2, you may have to rotate the oil pump ... so, the dist can be installed in Many different ways ... Regardless of that, EVERYTHING is based on relationship between Piston position & Zero Groove, so verify that FIRST.
Old Feb 18, 2020 | 04:01 PM
MelWff's Avatar
MelWff
That groove connects to a shaft that connects to the oil pump. If someone pulls the distributor and doesn't mark the location of the body and the rotor it can drop in wrong.
You say you are retarding the timing, are you using a timing light?
read the article below and note the comment on C3 distributor orientation
http://corvette-restoration.com/wp-c...stallation.pdf
Mrvettenick
Originally Posted by CV71H
Thanks!
Cheers
Es
OK, so the distributor was never removed? If that's the case, are you sure that the plug wires are in the correct firing sequence when you replaced the cap?
Old Feb 18, 2020 | 04:09 PM
KenSny's Avatar
KenSny
And of course, are the points set correctly?
Old Feb 18, 2020 | 04:34 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Is the distributor original to the car? If it is at the factory they made a deep mark when the timing was set. It is on the intake and the base of the distributor flange under the hold down clamp.
Old Feb 18, 2020 | 05:17 PM
CV71H's Avatar
CV71H
Hi Guys,
We'll check the damper on Friday!
I'm using a high-tech timing light with dwell-angle measurement function - the points are set correctly!
I think the distributor is original to the car, and we didn't remove it. I'll check if there are markings visible!
I have a feeling that the OT marking on the damper is off which would explain a lot!
Cheers
Es
Old Feb 18, 2020 | 05:27 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Sounds like something is out of position, either the distrib or the crank balancer.
Q: Did it run well before? and has the distrib been removed since? If Yes and No then it must be the balancer
To set everything:
  • Use piston stop to gently get close to TDC, mark balancer with pencil in each direction, FWD/Reverse TDC is the middle of that.
  • Hopefully that hits the mark on the balancer. If not it is bad, or timing tab is incorrect. If it is exactly 180 degrees off spin engine 1 turn and try it again.
  • Set engine to TDC by confirmed balancer mark. Make sure on #1 firing stroke. Valves don't move for 90-180 degrees.
  • Check that rotor is pointing to #1 terminal in pic below. If not pull distrib.
  • Distrib rotates a tooth when inserting, keep trying until rotor points at #1 spot. Easier if you mark desired #1 position with masking tape. Oil pump shaft may need to be bumped a little with a long screwdriver for slot to engage at correct position.
  • Rotate housing til vac can and window look like pic below. This is the only way vac can can fit inside the shielding on a corvette. I believe the window points to cyl #2.
  • Rotor is now pointing at your new #1 distrib cap terminal. Install wires,
  • You can even pre-set the timing with a continuity light (with points) before engine fire up. Points should open (no continuity to ground) (fire the plug) at exactly "X" degrees TDC.
  • If you need to move the vac can after that, to get it to fit in the distrib shield, move the distrib 1 tooth and try it all again.
Old Feb 19, 2020 | 05:26 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
  1. find tdc and locate timing mark so you know you are on the firing stroke
  2. look at rotor to find #1 on the cap
  3. retrace every plug wire to make sure you are putting them on the cap in the right order 18436572
  4. look at the above diagram from Leigh to locate chevy cylinder order. Other car manufacturers are different if you are used to working on a different make
  5. then try and start and time with the light.
Old Feb 19, 2020 | 10:15 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Reclock the distributor......it is a tooth or two off......remember.....#1 can be anywhere....what is important is how it is relevant to the cap.
Jebby
Old Feb 19, 2020 | 12:26 PM
68blvert's Avatar
68blvert
Find tdc for #1. Balancer mark should line up with 0°. Rotor should point to wherever you have #1 plug wire at cap. If balancer lines up but rotor don't you jumped time. If rotor lines up but balancer don't, balancer has slipped. This all assumes distributor hasn't been disturbed before work was done.
Old Feb 19, 2020 | 05:25 PM
7T1vette's Avatar
7T1vette
You MUST set timing before setting dwell and before adjusting the carb. If you have trouble setting the timing, you are wasting your time doing 'other' adjustments.
To set timing, you MUST know that the "O" (top dead center) mark on your timing scale is close to correct. Do an internet search on HOW to set your engine to TDC. Also, since the engine is a 4-cycle system, the ignition spark must be set on TDC-compression (rather than TDC-exhaust).
Once you are sure that ignition timing is correct, then set the dwell (points system only). After that you can move to carb adjustments: set idle mixture screws FIRST; then set choke; fast idle; curb idle. Good luck.
Old Feb 19, 2020 | 06:30 PM
lars's Avatar
lars
That's not correct. The diagram shown is for HEI - not for points distributors. Do not use the diagram shown above for a points system. For correct info on how a points distributor should be installed, e-mail me for my paper.
Originally Posted by 7T1vette
You MUST set timing before setting dwell and before adjusting the carb. .
That's not correct. The dwell must be set before the timing is set. Dwell affects timing, but timing does not affect dwell.
Lars
V8FastCars@msn.com
Old Feb 20, 2020 | 04:16 PM
CV71H's Avatar
CV71H
Lars
V8FastCars@msn.com
Thanks for the paper Lars!
A quick question: which is the standard location for #1 on the cap?
To Help with 1972 LT-1 ignition
Old Feb 20, 2020 | 04:17 PM
lars's Avatar
lars
It's shown in the photo and the diagram in the paper I sent you.
Old Feb 20, 2020 | 05:00 PM
CV71H's Avatar
CV71H
Thanks Lars (and the rest of you guys too!)!
I'm convinced th distributor has been fitted in the "non-corvette" way on my friend's car!
We'll start working on it tomorrow afternoon!
Old Feb 21, 2020 | 01:19 AM
20mercury's Avatar
20mercury
Default Much Thanks!
Lars
V8FastCars@msn.com
Wouldn't you just know it, I just swapped out the intake on my 72 LT-1 project from a Torker single plane back to the OEM intake and of course I must have accidently moved the distributor so when I reinstalled it, of course it would not start. So I used the HEI diagram above which made the situation worse for a 72 points distributor, LOL's. So thanks to Lars for the points setup info. And as info, I did not use Lars distributor location in his papers photos but rather the alternate C3 distributor location that Lars also outlined for the C3 which straightens out the tach cable. This alternate C3 distributor location has the plug wires CCW "clocked" one tower and changes the vacuum advance location from 7 o'clock to 9 o'clock. Also found a GM service bulletin in the back of a 68/69 NCRS manual which said the same suggested change. Just another day in the Corvette C3 adventures, ha, might be useful or entertaining to someone.
