Overheating
Old Mar 8, 2020 | 09:43 AM
brisa2016's Avatar
brisa2016
Navigator
Default Overheating
Ok, new radiator, water pump, and thermostat was put on and in ,in 2005. Car has been overheating for the last couple of months to the point of boiling th coolant in the overflow reservoir. How do I find out if I have a block in the radiator or somewhere else? Cant figure it out. Took mechanical fan off and put on electric fans with shroud that produce 3600 cfm. That should be adequate right?very frustrated
Old Mar 8, 2020 | 10:09 AM
interpon's Avatar
interpon
Pics? Year?
all gaskets in place to direct air?
fans running right direction.
Old Mar 8, 2020 | 10:21 AM
jackson's Avatar
jackson
? have you tested for blown head gasket / cracked head ?
Old Mar 8, 2020 | 10:34 AM
diehrd's Avatar
diehrd
After 15 years I would flush the system , replace the thermostat and gasket and refill w/50/50 mix.
Old Mar 8, 2020 | 02:33 PM
60 SHARK's Avatar
60 SHARK
Hope you serviced it several times in all those years, , , if not, likely its ALL clogged up, the coolant may still have a color, but that dosent mean it's still good,,,
new fans won't fix it,,,,
Old Mar 10, 2020 | 01:48 AM
7T1vette's Avatar
7T1vette
If it worked well with that configuration in prior years, you just need to restore the condition to prior state. In 15 years LOTS of things can go wrong. And most of those 'things' occur because of LACK of use. A regularly used cooling system that is maintained well most often works for decades...until a thermostat, pump, belts, and/or hoses wear out. The metal spring in the lower radiator hose can be a problem (it's there to keep the hose from collapsing at higher RPM's) if it disintegrates from rusting away after many years.
Use 50/50 mix of antifreeze and distilled water for coolant; change it out about every 3 years or so; flush the system before alternate coolant changes and replace the thermostat/gaskets after you CLEAN the system.
So, try flushing the system. If the radiator appears to have lots of scale build-up in the side tank/fins, use radiator CLEANER to de-scale it, first. If you think the hoses, belts and T-stat need to be replaced, have at it. It's probably well overdue.
To Overheating
