HEI distributor connector?
Old Nov 21, 2002 | 11:58 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default HEI distributor connector?
Does anyone know of a source for the connector that the power and tach wire are attached to, that plugs into the GM HEI distributor. I'm getting ready to fire up my ZZ4 and I'd like to have a neat looking connector to my distributor.
Thanx
Old Nov 21, 2002 | 05:30 PM
Smokehouse69
Default Re: HEI distributor connector? (Smokehouse69)
Is the part listed in the AIM of HEI equipted cars?
Old Nov 21, 2002 | 05:54 PM
Todbo's Avatar
Todbo
3W.PERFORMANCEDISTRIBUTORSDOTCOM, that little bitch can be hard to find :smash:
Old Nov 22, 2002 | 12:56 AM
jackson's Avatar
jackson
Thanx
Me Too smokehouse! I 'm looking for a single connector that has two female terminals. I looked at those at performance distributor site ... they're simply single connector with one terminal each ... nuthin special. I have need for 3 or 4 of the dual-terminal connectors right now ... so if someone finds a source that comes in bags of say 10 or whatever ... i'd sure be willin' to spring for half. I've just sent off for a catalog from Newark Electronics ... maybe I'll find em there. Smokehouse ... please email me if you find a source. Thanks
Old Nov 22, 2002 | 01:11 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: HEI distributor connector? (jackson)
Summit racing has the power connector in the catalog. look in electrical or around the distributors.
You can usually use a good spade terminal for the tach, unless you are going for the totally stock look.
I don't recommend the spade terminal idea for power as with the heavy wire they are prone to slipping off and you loose all power to the plugs (dead engine) and it could happen at the worst possible times. If you tach comes un-plugged -- oh well.
Old Nov 22, 2002 | 01:33 AM
jackson's Avatar
jackson
Default Re: HEI distributor connector? (BSeery)
The problem with the single types is that they are MORE prone to arc between BAT & TACH terminals than the dual connector ... the dual connector has much more plastic "beef" in between. Trust me, they will arc ... or I wouldn't be lookin' for duals.
Old Nov 22, 2002 | 05:28 AM
zwede's Avatar
zwede
Pep-boys has them.
To HEI distributor connector?
