Removing power steering control valve.
Old Mar 14, 2020 | 05:15 PM
DarrenX33's Avatar
DarrenX33
Default Removing power steering control valve.
Easy part was removing the pitman arm. But now I can’t spin the thing off. Looking for advice. Thanks.
Old Mar 14, 2020 | 05:37 PM
MelWff's Avatar
MelWff
Why did you remove the pitman arm?
Did you loosen the clamp and place the arm in a vise ?
Old Mar 14, 2020 | 05:46 PM
DarrenX33's Avatar
DarrenX33
Control valve is still in the car. I removed it from the pitman arm. But now I need to unscrew it from the drag link. Won’t budge.
Old Mar 14, 2020 | 07:22 PM
MelWff's Avatar
MelWff
Did you release the clamp holding it on the drag link?
Old Mar 14, 2020 | 07:38 PM
7T1vette's Avatar
7T1vette
Use a small chisel to drive into the gap in the clamp so it will spread a bit. That will make it loose enough to remove.
BUT, if you plan on reinstalling the same CV (after rebuild, paint, whatever), you need to mark the exact orientation of the CV on the drag link and also count the exact number of turns needed to free it from the threads to the closest 1/8 turn. That way, you know exactly how many turns to re-engage it on the drag link when you go back together with it.
Old Mar 14, 2020 | 07:39 PM
teamo's Avatar
teamo
Mine was very hard to remove. I removed all of the steering linkage and rebuilt/replaced everything. I had to put it in a vise and use a wrench on it.
Old Mar 15, 2020 | 08:44 AM
SteveG75's Avatar
SteveG75
You have to remove NOT just loosen the pinch bolt. The drag link is machined with a clearance notch for the bolt. After that, a little PB blaster and some channel locks and it will spin right off.
Old Mar 15, 2020 | 08:58 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Steve beat me to it, pull the bolt and pry open the slot slightly and use a very good penetrating oil to get into the threads
Old Mar 15, 2020 | 09:21 AM
DarrenX33's Avatar
DarrenX33
Appreciate it guys. Going to work on it today. 👍🏻
To Removing power steering control valve.
