auto shifter
Old Mar 20, 2020 | 11:58 PM
Ronnie_W's Avatar
Ronnie_W
Default auto shifter
For those that have installed a 700r4 or other A4s in your C3s, what shifters are you using? I have an M4 now.
Old Mar 21, 2020 | 06:13 AM
riverracer au's Avatar
riverracer au
i installed a 700r4 into my '72 a few years ago now.
i'm using the stock shifter with the Shiftwork's kit, but you can use the 700r4 without it, but you cannot manually select 1st gear.
if you search on here there are posts on how to modify your original shifter gate plate.
Old Mar 21, 2020 | 02:33 PM
7T1vette's Avatar
7T1vette
All you need to do is to remove the stock shift detent plate and grind/cut another detent notch in it for 1st range. Then you can pull the stock shifter back into that notch to keep it in 1st.
Having it in 1st is not really that important, as 1st gear winds up very quickly. The 'notch mod' is of little value unless you are drag racing the car.
To auto shifter
