Spreader bar installation tips please
Old Mar 30, 2020 | 10:09 AM
C3Newb's Avatar
C3Newb
Default Spreader bar installation tips please
For everyone that has installed a spreader bar on their C3 - what tool did you use to hold the head of the upper control arm bolt while removing the nut? I can almost get a socket wrench through the a-arm onto the rear bolt but nothing I have can grab the front bolt.
Last edited by C3Newb; Mar 30, 2020 at 02:29 PM. Reason: Corrected name of upper control arm
Old Mar 30, 2020 | 10:41 AM
GUSTO14's Avatar
GUSTO14
Are you telling us this entire bolt is spinning as your try to remove the nuts?
These bolts have knurling under the head of the bolt that is supposed to grip the mount as the bolt is drawn in by the nut being tightened.
If someone uses an impact wrench to tighten or loosen them they can easily strip the knurling from the bolt. If the bolt is spinning this may be the case. You may find some help here... https://www.corvetteforum.com/forums...-stripped.html
Good luck and let us know how it works out... GUSTO
Old Mar 30, 2020 | 02:27 PM
C3Newb's Avatar
C3Newb
Yep, that's exactly what's happening - they spin freely when I try to remove the nut.
Thanks for the link - that explains everything! Looks like I get to replace some bolts once I figure out how to access the heads.
Old Mar 30, 2020 | 06:07 PM
vette427-sbc's Avatar
vette427-sbc
Get a pry bar to put pressure on the bolt head while you turn the nut. Sometimes it gets pushed out and the knurl has nothing to grab anymore. Dont use an impact gun to remove the nut, if the threads arent messed up and the knurl isnt totally gone you should be fine.
Old Mar 31, 2020 | 08:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have tthe same issue. Make sure your front end is jacked up while loosening the bolts. I was able to get a wrenc in there from underneath. I think it was a stubby. I'l go check since I have to take one side off to get my engine in with the fuel pump installed
Mine were a 5/8 head
Old Mar 31, 2020 | 08:33 AM
Rescue Rogers
Old Mar 31, 2020 | 11:19 AM
71 f/w driver's Avatar
71 f/w driver
rescure roger has the right idea, using a stubby, I bought a cheap box end wrench from harbour frieght and cut it into the size that fit into that space.
Mike
Old May 2, 2020 | 09:47 PM
C3Newb's Avatar
C3Newb
Thanks for the suggestions, everyone.
Success! I ended up buying a set of 60 degree deep offset wrenches that did the trick. Only the driver's side bolts spun - the passenger side bolts apparently still have the knurling intact.
Old May 2, 2020 | 10:17 PM
Big2Bird's Avatar
Big2Bird
I think it was NAPA that had bolts for that with oversize knurling/shank.. Maybe Dorman.
When I did my front they were toast. Redone as factory.
Installed a spreader bar.
Lightweight 81 frame is now cracking. Hmmm
Old May 4, 2020 | 09:07 AM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Where is your frame cracking?
Tom
Old May 4, 2020 | 11:07 AM
Big2Bird's Avatar
Big2Bird
Tom
Around the spring pockets and shock towers.
Old May 4, 2020 | 09:03 PM
Sky65's Avatar
Sky65
Thanks.
I have a 78 frame under my 65 and it has cracked the bottom of both frame where the engine crossmember is welded on. I have a spreader bar but also continuous welded the rail seams and gusseted it per the GM Performance Manual. I don't race the car I just thought it wold imorove the car. It handles great but the ridre can be harsh. I have VBP dual mount springs front and back and SPAX shocks.
Tom
Old May 4, 2020 | 10:27 PM
Big2Bird's Avatar
Big2Bird
Thanks.
Tom
I have bilsteins and 460?# springs in front and 330?# rear springs and it rides and handles smooth.We are adding the gussets next repair. 2 weeks.
You almost have to pull the body to get it welded right.
Old May 4, 2020 | 10:42 PM
Sky65's Avatar
Sky65
I agree. I was in an accident with the car a few years ago. I got cut off and t-boned a Jeep. While the body was off being fixed I replaced the frame with one from a 78. That's when I continuous welded and gusseted the frame. I also completed the modifications to make it fit a midyear. I don't think the gussets are an issue for ride quality. But IMO taking the flex out by continuous welding the seams does alter the ride. For a street car it may be too stiff. Again JMO.
Tom
To Spreader bar installation tips please
