Agonizing over engine swap
They started w/ a used (mileage unknown) 1 pc rms roller motor But they did Not do Any machine shop work aka $ labor. They even reused an old timing set.and all old OE bearings. Seems their Only new Internal parts were a gasket set, one camshaft & a set of pushrods. An informative article but mostly about how Not to proceed; especially for first-timers as they won't know how to assess old, used parts.
Your right that this level of doing it on the cheap is a trap for a first timer to try. And these guys weren't worried about it coming apart the day after they filed the article. But the fact is if you have good compression and oil pressure, the bores look good and pistons aren't pitted, you probably have a pretty solid base even without a full tear down, boring, new pistons, etc. etc. Let's face it, by the late 90's the quality of the engines had vastly improved. And even my 80 L82 took all the beating the twenty something I put on it for most of its 90k miles. If it were me doing this, I wouldn't dive in without knowing the actual miles on the engine.
My takeaway was that if a person isn't in rush and has time to hunt around for some good deals, they can likely get $5k or $6k worth of hp and reliability for $4k. If the OP simply followed these guys on the route they took up top to get the heads, manifold, and carb he's likely be $1k ahead of just plunking down the case for new. That's money that could then go into internals and machining.
A few questions:
- What is your total budget including the price of crate engine, labor and incidental parts that will need to be replaced?
- What is the condition and HP/TQ of your current engine?
- What is your skill level, extent of available tools and access to helpers?
- Is there a speed shop nearby to perform cleaning, machining and prep of your short block assembly?
DART Iron Eagle cylinder heads - light intake porting and bowl blending
Performance Advance Curve
Lars-rebuilt q-jet
Comp Retro Roller Cam Kit
Flat-top hypereutectic pistons
Hastings moly rings
1 5/8" headers
Dual exhaust with h-pipe
K&N air filter
Edelbrock Performer 2101 intake
There are a number of items also replaced (motor mounts, bearings, full gasket set, fasteners, water pump, starter, radiator, transmission, differential, oil pan, pump, etc.). It is probably a solid 370-395hp/tq engine. Plenty of fun and tons of seat-of-the-pants performance. Very durable setup.
1. My total budget is 4k.
2. The L-48 runs pretty good if a little hot. Its the original 73 so I’m guessing somewhere in the neighborhood of the stock hp/tq numbers.
3. I’m pretty handy. Ive done a couple complete engine swaps but I’ve never built one. I did some work for a mechanic who now owes me some work should I need it.
4. There are many machine shops in the Denver area.
I’m almost always a DIYer. I’m not easily intimidated by auto work. My hesitation with building an engine is the precision required. I’m perfectly comfortable torquing head bolts and manifolds to spec. But when it comes to plastigaging clearances I’m terrified. Putting an engine together with top of the line parts only to have it blow up on me is a learning experience I can’t afford. That being said, if there are significant cost advantages I would be willing to consider it.
Thanks again to everyone who responded or voted. This thread has really helped me with my decision! This community has been such a tremendous asset over the years. I’m on my 3rd corvette and part of the reason why I keep coming back is the community and culture that surrounds these amazing cars! Thanks again!
Plastigage is stupid simple; I use it as reality check behind real gaging. Hopefully your mechanic will have mics & bore gage & knowledge & experience w/ them ...
... use plastigage as a secondary checking method rather than as primary gage.
I have discovered the LS swap. Though it seems that the further down this rabbit hole I venture the more confused and inundated with info I become. It would also seem that the advent of this new option has had an effect on the more traditional options. In the Denver area I have found big blocks to be plentiful and inexpensive. There are also many SBCs for sale near me that are affordable.
My budget is 4k. I would like to have around 400hp. The car is driven a couple days a week. Mostly just street cruising. But I want driving this car to be as much fun as looking at it is.
What is the best way to accomplish this within my budget? My heart says old school SBC. On the other hand I’ve never had a big block and the thundering appeal there is obvious. Especially considering that I’ve seen several near me for under 1k. Obviously the real expense there would be in making the thing perform like I want. Is it even possible with my budget?
I am very intrigued by the LS swap. The drivability, mpg, OD transmission, all appeal to me. Not to mention the hp. The sheer volume of conjecture surrounding this gives me pause though. I have waded hip-deep into the LS threads and there doesn’t seem to be any consensus on the best way to do it.
All this brings me back to the 383. I have seen these in the 4K neighborhood with a warranty. The drop-in, bolt-on nature of this is a huge benefit. The old school look and lopey sound of a properly cammed SBC is how I imagined my dream car. Which this is. I only want to do this once.
So, are either of the 2 options I hadn’t considered (big block, LS) realistic at my budget? Does one provide substantial benefit over the others? I want this thing to rip! I want it to sound good doing it. I do want some measure of reliability. I know the old adage, you can have fast or cheap, but not both. But my budget is what it is. If you’ve made it this far, I would like to thank you! I’m throwing this out there knowing that it will be met with a measure of eye rolling but I am hoping that under the circumstances there may be others who, like me, find themselves with an abundance of free time and wish to opine on this age old topic! Or those that wish to share their experience with these engines. Thanks in advance to any and all who take the time to help me out! I am itching to pull the trigger and get my baby back on the road!
Also make you check the valve guide to valve retainer clearance if you run any kinda large cam. The OE guides will hit the retainers. Again easy fix for a competent machinist but be aware.
So I bought another project car for her, we'll both end up with what we want. Hers is a '78 that will get an LS6 out of a 2003 Z06 (25th anniversary Corvette with the engine out of a 50th anniversary Corvette) and mine will be a fire breathing solid roller 4.635"x3.766" nasty bastard.
Fuel lines: If you convert the car to EFI the lines will have to be inspected and figuring out the pump and fuel pressure regulator situation will be 300 hundred dollars if not more depending on what all needs done. If he converts it to carb, dizzy, and mechanical fuel pump he would have probably $800 in it there but the existing fuel system could be reused.
Electrical system: The OE system may not be up to the task of running a PCM and all that fun stuff. Plus if you fuel inject it you’ll need to either fabricate your own harness (Not hard I’ve done it several times with 4-5 swaps) or purchase a pre-made harness for several hundred dollars. Converting a LS to carb would eliminate this but converting a LS to mechanical fuel pump and dizzy isn’t the cheapest.
Exhaust system: Never swapped a C3 with a LS but any header is gonna be expensive. If OE manifolds will work then that can save a bunch. Just don’t know what will fit.
Given the OP is on a 4K budget sticking with a SBC is the way to go.
