Reproduction Speedometer
Old Apr 5, 2020 | 04:56 AM
C34ever's Avatar
C34ever
6th Gear
Default Reproduction Speedometer
Hi guys,
it all startet with my odometer quit working on my 1970. My plan was to rebuild my original speedo as much as possible to get it work properly. I studied mechanical engineering and have lots of experience so I thought that's possible to do it by my own. BUT, I live in Germany and its nearly impossible to get all the neccesary parts for the rebuild. Than I saw this reproduction speedometer on Zip Corvette and I thought that could be a good compromise. Does anybody know those speedos? Can you recommend them?
Best regards from Germany
Sebastian
Old Apr 5, 2020 | 12:08 PM
MelWff's Avatar
MelWff
Zip is a well known supplier of aftermarket parts but cant give you any specifics on the speedometer they sell
https://www.zip-corvette.com/69-71-speedometer.html
Old Apr 5, 2020 | 03:22 PM
Haggisbash's Avatar
Haggisbash
I used the repro tachometer, it was identical to the original and works well for two years so far.
Old Apr 5, 2020 | 05:32 PM
Barry's70LT1's Avatar
Barry's70LT1
https://www.corvetteforum.com/forums...-odometer.html
My new speedometer that I purchased works well now. At first it was noisy, so I took it apart and greased all the dry shafts/bushings. Either it got missed getting greased when made or they were very stingy with the grease.
I have not installed my repaired original yet, maybe this Spring.
To Reproduction Speedometer
