Hey guys, so I've got an AFR gauge and I've been seeing that my ratio drops as low as 17:1 under full throttle. I'm really not sure why this is happening, I don't seem to have any issues holding 6.5 psi fuel pressure and have a pump with plenty of gph.
So I have this carburetor (It's a Quick-Fuel style 650 vac secondary). I have 67 Primary jets (little rich at cruise so probably should be 65), 76 secondary, a 5.5 PV. According to the spec sheet that came with the carb it has a 33 pump nozzle, 31 high speed air bleed primary and 31 secondary, 63 idle air bleed primary and 63 secondary, a 46 primary power valve restriction (and a plate.. thing in the secondary side), and a 97 needle seat on both primary and secondary.
Vacuum Secondary. Does it have springs like a Holley 4150?
Nah it's an adjustable just like this one, but if my secondary isn't opening enough would that really cause a lean condition? If I understand correctly the secondary adjustment effects both fuel and air on the secondaries, no?
try either leaving the gas cap off or loose to see if that effects the lean at WOT problem, we have seen quite a few lean at heavy throttle condition problems that were caused by a fuel tank venting problem. Henry @ olescarb
2016 C3 of Year Finalist
Whats your fuel pressure, when my carter was failing it would do this. It would pump enough fuel to run and keep up under normal low power driving, but was only putting out about 3 psi. Not enough for W.O.T
So that didn't have any effect unfortunately. Also, don't know my fuel pressure at WOT (it's at 6.5 steady in the driveway at all throttle positions), don't really have a way to check it while driving.
Remove the secondary jets and see if it goes pig-rich at WOT. If it's still lean at WOT, the carb has a secondary fuel feed problem - maybe a passage or two not drilled in the metering block or the carb body.
You could try blocking the secondary's closed and just go WOT on primaries to see if it does better. If you can get a longer line for fuel pressure gauge you can route out from under hood and use wiper blade to hold it for a quick blast. Some tape will hold it steady.
JIM
It aint fixed til you put duct tape on it!!! Haha I carry a roll just as a threat not to break down
JIM
Haven't tried Lars suggestion or this one for blocking the secondaries. But I tested my fuel pressure! It seems like my fuel pressure is pretty stable at WOT, so next thing I'll try is removing the secondary jets.
And you are sure that pushing the accelerator pedal to the floor (NOT working the carb linkage by hand) actuates the secondary vacuum system AND the vacuum signal will pull them completely open?
