Holley 830dp woes
(Question 1) On stripping the carb I found both primary and secondary PV’s were 6.5hg, I would of thought that this was too high for my engine with a idle vacuum of 9hg at 850rpm
(2) I fitted 2no 3.5hg PV in both metering blocks as I have read some guidance saying that you should fit a PV half of your vacuum at idle?
(3) I reassembled the carb after checking everything else was working fine, i.e. float valves. The transfer slot was set at about 20 thou visible from the underside of the Carb, and then installed it on the car.
(4) I need help with this one. What is the purpose of the transfer slot? Is it a guide for butterfly setting point to allow for air flow at idle. Does this not become obsolete when you have holes drilled in the butterflies anyway?
(5) I had set all 4 corner idle screws out 1and1/2 turns. On initial start up after feathering the throttle a bit it was idleing at about 1400rpm and didn’t change much even once it was warm, so I backed off the throttle stop screw to lower the idle but it would not drop below 1000rpm, with the throttle blades closed completely. I started to adjust the 4 corner idle screws and all that did was increased the revs back up to around 1400rpm again and I was wondering why. The only way I could drop the engine revs was to nearly close off the idle screws in the secondary metering block. But what is the point of that, when they should all be the same
I have watched numerous youtube videos videos on how to tune a carb with 4 corner idling and have done my carb before I changed the PV’s, with no problem at all, but now I’m stumped, as to why I can’t find a way to lower the idle speed.
Will the holes in the butterflies draw fuel from anywhere else in the system with the throttle blades closed or is it only possible through the idle circuit? No fuel is coming through the primary or secondary boosters at all when idling, so its not from there. With a vacuum of 7in hg it is possible to draw fuel through the PV or not if the PV is a 3.5in hg. I have not changed any jets at all everything else is as it came out of the box 10 years ago.
The Car did run ok before but just idled very rich, and had a problem with no secondary squirter, that caused a slight bog when the secondary’s opened, which was why I took it off.
Peter
(2) I fitted 2no 3.5hg PV in both metering blocks as I have read some guidance saying that you should fit a PV half of your vacuum at idle? Not always....it is more about when the vacuum drops. 9 hg is very low. How big is this cam?
(4) I need help with this one. What is the purpose of the transfer slot? Is it a guide for butterfly setting point to allow for air flow at idle. Does this not become obsolete when you have holes drilled in the butterflies anyway? No....some cams are so large that to set an idle the blades uncover the transfer slot.....drilling holes in the plates allows you to close them further. It is important to have a vacuum drop on one side of the transfer slot for the idle circuit to function properly.
(5) I had set all 4 corner idle screws out 1and1/2 turns. On initial start up after feathering the throttle a bit it was idleing at about 1400rpm and didn’t change much even once it was warm, so I backed off the throttle stop screw to lower the idle but it would not drop below 1000rpm, with the throttle blades closed completely. I started to adjust the 4 corner idle screws and all that did was increased the revs back up to around 1400rpm again and I was wondering why. The only way I could drop the engine revs was to nearly close off the idle screws in the secondary metering block. But what is the point of that, when they should all be the same Are the secondary throttle blades shut all of the way? If so then you have vacuum leak somewhere. Sniff it out with an unlit propane torch.
then when the throttle blade begins to open more of the fuel form the transfer slot happens. Basically that's why it called transfer.
nt cause any issues. how much initial timing do you have. Good amount there is a good place to start. You are right the fuel enrichment valves dont play any part in anything till the carb gets into the main booster operation.
Is it worth backing the timing off to 8deg and start again there? I only put more advance in the initial timing as it improved pick up from idle.
Cant remember exactly but I think my Camshaft, Hydraulic Flat Tappet, Duration 292/292, Lift .550/.550,
TC 2400 stall.
TC 2400 not sure what cam you have but even if hydraulic adjust things where you see more like 18 at idle and if you have big cam you need even more then that at idle. BBC has big cylinders and big diameter head chambers.
put more timing in it. Then start looking into the carb for what other problem may have happened. Good chance with that cam you need some more total timing as well. I'm thinking you need like 20 at the idle and 38 to 40 total. 3000 rpm is a wise move on pump gas dont go down lower then that.
Is this an older 830 or is it one with a idle air screw hidden down in the air cleaner stud hole maybe?
You've got to find where it's getting air. It should be able to overcome the holes drilled...but they aren't helping on this combo for sure.
JIM
TC 2400 stall.
Most likely, this is your cam:
https://www.summitracing.com/parts/cca-11-213-3
This is not terribly big for a 460 inch BBC........you should have more than 7 inches vacuum at idle. I have the small block version of that cam in my 406 and it pulls 10-11 inches.
I feel this is where the problem lies.......I feel you have a vacuum leak somewhere.
Also....could you post a pic of the holes in the plates? 3/16" is huge.....and this in itself could be the issue. If they are actually .1875 in diameter.....you need to solder them up. Four .1875 holes is a LOT of air to pass at idle.....I have built plenty of setups that had that much cam and ran standard plates with no issues.
I just do not feel that that cam needs holes in the plates.......factory L-88's had more cam in them stock and they idled with no holes in the plates......if you had a solid roller with, say, 260 @ .050...then yes....that would work.
Easy thing to do would be to buy a new throttle plate and try it......or solder them up.....soldering them up is easy and free...the cost of a gasket to remove the throttle plate.
Another thing......very few carbs have two power valves in them anymore and they are usually for boat applications.....or road course where you are modulating more than 1/2 throttle to WOT in and out.....which is rare. If it was mine I would block the rear one off and add 8 jet sizes. One less thing to fail....and not needed once the engine is on the cam and accelerating.
Jebby
