Safety loop picture
Old Apr 13, 2020 | 08:35 AM
70rs/ss396's Avatar
70rs/ss396
Default Safety loop picture
This is how my safety loop looks like, if someone needs inspiration 😀
Old Apr 13, 2020 | 11:13 AM
Mooser's Avatar
Mooser
Looks substantial and fits in the tight tunnel area available, what's the material?
M
Old Apr 13, 2020 | 11:21 AM
Quackster's Avatar
Quackster
Fabrication looks really nice! I have one question, may be dumb, but gonna ask anyways. Enlighten me what it is for? I have an idea that it is made for keeping the driveshaft from dropping and tearing everything up and I assume it is for racing? Inquiring mind would like to know?
Old Apr 13, 2020 | 12:06 PM
70rs/ss396's Avatar
70rs/ss396
That is 100% correct 😃
Old Apr 13, 2020 | 12:11 PM
70rs/ss396's Avatar
70rs/ss396
M
I dont know exact What material it is, but it is some sort of galvanized Steel.
Old Apr 13, 2020 | 01:46 PM
gkull's Avatar
gkull
Summit racing sells this loop for cars with a floor pan. I just changed how it was mounted . My custom exhaust pass under the cross member for full length 3 inch exhaust
Old Apr 13, 2020 | 07:18 PM
Cool95vette's Avatar
Cool95vette
The clearance looks really tight. How do you keep the shaft from not touching the loop? Even with solid engine and trans mounts there's some movement.
Old Apr 13, 2020 | 07:28 PM
bazza77's Avatar
bazza77
I have seen a car on a dirt track do a complete flip because the front end of the drive shaft dropped and dug into the ground .If the back end broke it would just drag and more than likely pull the whole thing out and go rolling along the road in a shower of sparks .
But seriously , that shaft can get up to 6000 + rpm in a performance corvette, if it comes loose there's only a thin piece of fibreglass between it and your bum in the seat .
Old Apr 14, 2020 | 12:19 AM
gkull's Avatar
gkull
6000 rpms........ how about over 9000 rpm with an OD Tranny and a 4.11 rear end .
be
Actually with a quick calculator I have been up around 9300 rpm drive shaft rpm. Some things kinda scare me other than just passing the safety rules to be able to compete
Old Apr 14, 2020 | 06:49 AM
bazza77's Avatar
bazza77
well I did put the + after the 6000
Old Apr 14, 2020 | 07:41 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Who made it. I like it. i'm in need of one and keep forgetting when i do an order
Old Apr 14, 2020 | 07:53 AM
Rescue Rogers
You inspired me, I just ordered a generic one I can modify to make it stronger and better. Thanks!!!!
Old Apr 14, 2020 | 08:43 AM
Mooser's Avatar
Mooser
I'm usually more concerned with what would happen when one of the 1/2 shaft ones lets go. I've got making a set of those loops on my back burner but it never seems to get to the front. The front one as shown would be fairly easy (in comparison) maybe I should add that to my never-ending list of shelter-in-place jobs
M
Old Apr 14, 2020 | 10:46 AM
kossuth's Avatar
kossuth
In short as others have mentioned it’s part of the rules. Most specifically the IHRA/NHRA rules where any car with slicks running faster than 14.0 has to have one and any car faster than 13.0 on any kinda tire has to have a loop.
Granted many tracks are pretty lenient on this rule given how fast many newer street cars are today right off the lot but that’s the rule and it protects you and the guy in the lane next to you.
Old Apr 14, 2020 | 10:56 AM
Rescue Rogers
M
I have a set of those from someone like racevette or vansteel or somone. Its nice to have the state of mind that the half shaft isnt going to visit the battery or inside the cab.
Old Apr 14, 2020 | 11:02 AM
Mooser's Avatar
Mooser
Gonna start up a new thread
M
Old Apr 14, 2020 | 11:09 AM
BKbroiler's Avatar
BKbroiler
I have half shaft and drive shaft loops from Dragvette Products.
To Safety loop picture
Old Apr 14, 2020 | 11:11 AM
jackson's Avatar
jackson
Lotsa track/class rules Mandate loop ... just as shaft's required to be painted White ... so others can see it better if/when it does come out.
Old Apr 14, 2020 | 12:38 PM
BKbroiler's Avatar
BKbroiler
This is the Dragvette loop. It is centered in the car, but the drive shaft isn't, so there is only about 1/4 inch clearance on the right side. I have solid motor mounts and a rubber trans mount and the shaft has never contacted the loop.
Old Apr 14, 2020 | 02:32 PM
70rs/ss396's Avatar
70rs/ss396
I dont know who made it, it was on the car when I bought it.
