Bad Bad Engine noise
Some additional history...
The Made in Mexico 350 was installed 2 owners ago. The previous owner installed tall of the aftermarket parts - Heads, intake, carb, cam, MSD ignition, etc. I have had the car for several years now, and put around 4000 miles on it. There was a coolant leak into one of the rear cylinders - I believe #8. There was never any oil in the coolant or coolant in the oil, but it went through coolant and the right side exhaust would blow a little bit of white smoke and smelled like coolant. I had a friend who owns a repair shop service it last fall. They pulled the heads and determined that the leak was coming from one of the head bolts - there seemed to be no sealant on the bolts. In addition to all of the dis-assembly / re-assembly required to replace the head gaskets and seal all the bolts, they also removed the starter to install a missing flywheel shroud. I have had no cooling issues since then.
My friends' shop that did the last work is closed due to COVID, so I am appealing to the forum for help. Thanks in advance.
https://www.dropbox.com/s/336h296dhf...noise.mp4?dl=0
Are you losing power noticeably ? If so, it's probably even worse than wag1or 2.
Is oil pressure normal ? any change ?
Water temp normal ? any change ?
Disconnect the transmission and see if it makes any difference.
"It's getting worse in a hurry" sounds very bad. I suspect something is coming loose and you don't want it to come completely off. Auto or stick? Loose auto flexplate?
Do you have a stethoscope or a long screwdriver to help isolate the noise?.
Dang "quarantine" I'm only 40 miles from you.......
Something is broke somewhere.
Not good at all, at least when my engine went it was done making noise in a couple of seconds, then locked up tight. Yours sounds like a gremlin is in there beating with a hammer for you to let it out.
That may be it. ...hope so ... if it's an auto trans ... if so, flexplate is cheap to buy & not so difficult to R&R.
-add-
If it's either broken up clutch or flexplate ... regardless ... that shrapnel can (and has) busted & ruined back of block $$$.
Do Not run it.until you've either fixed it or verified it's not that.
