Windage tray question
Old Apr 27, 2020 | 06:01 PM
Cool95vette's Avatar
Cool95vette
Default Windage tray question
I am getting ready to install a windage tray in my 383. I've read that they need at least .10 minimum clearance from the crank. My question is do I want to have it as close to the crank as possible or is there an ideal clearance I should go for. Thanks.
Old Apr 27, 2020 | 07:23 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Depending on the studs that you use, I don’t think you’ll be able to move them closer to the crank without machining. I’ll be interested what others have to say as I never “fitted” mine. Just made sure it didn’t hit.
Old Apr 27, 2020 | 07:31 PM
Vette5311's Avatar
Vette5311
I saw a video one time of a sbc with a clear oil pan. Can’t remember by who but it was about fitting crank scrapers on the side rail. The amount of what they called “roping” was unbelievable. Reminded me of those candy machines that they use to stretch taffy! The crank dipping in the oil carries a lot of oil wrapped around it so I would say the closer the better as long as it clears and allow for any heat expansion.
JMHO
Old Apr 27, 2020 | 08:41 PM
KenSny's Avatar
KenSny
Some pan manufacters say 0.030-0.040.
In the old days I installed at 1/8" (0.125") in my stock chevy oil pans.
Just make sure you have good clearance between the tray and any rotating part. I don't think for a street engine it is super critical, since you are not maintaning high rpms for extended periods of time gleaning every last hp out of the engine.
Old Apr 27, 2020 | 08:59 PM
Cool95vette
She's on the track 90% of the time. There's a C4 there that I can't quite catch. He's running in the 6.70's and I'm in the 6.80's. So I am actually trying to find every little bit I can.
Old Apr 27, 2020 | 10:08 PM
KenSny's Avatar
KenSny
On a straight drag track I would think baffles in the pan would gain more. All the oil surging to the rear and probably over the back of the tray.
I never tried to shave tenths of a second, so I'm just guessing.
Good luck.
Old Apr 27, 2020 | 10:45 PM
bashcraft's Avatar
bashcraft
A wind age tray won't gain you any time. It'll keep your oil pressure more consistent by reducing airation.
Old Apr 28, 2020 | 12:17 AM
gkull's Avatar
gkull
That is a very respectable time. I never got 6.80 in the 1/8th even with my 10.96 1/4. My vette was never optimized for drag racing it was straight off the road racing track with a 5 speed.
But anyway please tell me about the motor. My solid roller 383 was only a 11.70 consistent drag racer when I had an auto tranny.
I have the 8 quart with adjustable side scrapers. I had to set it all up and they said something like .035 One of the easier ideas is to use 14 inch header collector extensions and get a vaccum pump that can get you down to about 16 inches of vacuum in the block
Old Apr 28, 2020 | 12:21 AM
Vette5311's Avatar
Vette5311
Good luck.
I used to run one of those on my drag car. It is a flat steel plate that bolts between the oil pump and the rear main cap. It is contoured to fit closely to the rear of the oil pan. On launch when the oil try’s to climb the back of the pan it holds it back in the sump. May not gain any tenths but it will keep your day from being ruined when the oil pump pickup uncovers and sucks air!
Old Apr 28, 2020 | 09:24 AM
Cool95vette
Good luck.
My oil pan is baffled already.
From what I've learned it does help. Not a lot but it does free up a little of power.
It's a 383, Comp solid roller cam (268/274, Lift .552/.564) Still pulls 17" of vacuum. Edelbrock RPM heads, dual quad tunnel ram with 2x450 Holleys, MSD ignition, and 150hp shot of nitrous. th350, and 4.11 gears.
My best pass.
Old Apr 28, 2020 | 11:20 AM
gkull's Avatar
gkull
My best pass.
That's what I was missing was the 150 shot my 11.70 383 had a much bigger solid roller and much bigger heads. I did have the hot rodded TH350 with a 3500 stall and 4.11 until it blew chunks in the pan. I'd get the morroso scraper kit, belt driven vacuum pump, and 12 -14 inch collector exstenions. electric water pump is a power saver.
I started out with 9X28 Goodyear slicks and later on moved to 10 inch. I used the low burn out compound and they really last compared to hoosiers.
Weight is a big thing. I pulled all the metal out of the front of my 79
Old Apr 28, 2020 | 11:48 AM
Govette1975's Avatar
Govette1975
Default Go online
Engine Masters did a test on oil control and horse power gives you a good look at what controlling oil does for horse power. Motortrend channel
Old Apr 28, 2020 | 03:55 PM
lars's Avatar
lars
Actually, I have done dyno testing of an engine with and without windage tray. The windage tray reduces/prevents the crank weights from whipping through the massive oil splash that is whipped up out of the pan at elevated rpm. My data shows without any doubt that the tray is worth about 5hp at elevated rpm.
Lower the oil level in the pan by a quart or two for the Banzai run and you'll get another 2-3hp out of it.
Lars
Old Apr 28, 2020 | 05:43 PM
7t9l82's Avatar
7t9l82
Lose a hundred pounds in the car somewhere and you'll pick up your tenth.
Old Apr 28, 2020 | 06:48 PM
Cool95vette
I agree but I've taken most everything off I can. I am looking at the air reservoir and rear bumper stuff that I saw removed in a weight loss thread I've read on here. I'm hoping between the windage tray, electric water pump, and going from a 28" tire to a 26" tire I can get that tenth. I don't feel comfortable putting more nitrous to the engine so I'm looking at parasitic loss of power.
Old Apr 28, 2020 | 07:51 PM
Gunfighter13's Avatar
Gunfighter13
You want a louvered tray. Milodon makes some good ones.The only other advice is to replace your carbs, To small for your setup. This is what you need. https://www.holley.com/products/disc...t/parts/0-4224........
https://www.racingjunk.com/Carbureto...=1&from=search......
https://www.racingjunk.com/Other/184...26&from=search
....They are out there just check around.......or up grade to a pair of Holley 600cfm carbs.
Old Apr 28, 2020 | 08:32 PM
Gunfighter13
https://dallas.craigslist.org/ndf/pt...103466220.html.....
Another good set
To Windage tray question
Old Apr 28, 2020 | 08:34 PM
jackson's Avatar
jackson
louvers ...diamond stripper as well
Old Apr 28, 2020 | 09:02 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
We never really messed with windage trays unless they came with the pan that was spec'd. They just don't do a lot for power for the amount of headache they are.
Windage trays never fit, ever.....out of the box.......and installing one on your car from underneath would be something. You will have to trim somewhere and dry install the pan a bunch of times.
BUT....they do help....a little.....BUT they were not really designed for horsepower gain as much as high RPM oil control for extended periods.....the Diamond shear type are the best.
Someone suggested a vacuum pump......and you can pick up a lot with one. Plus it will improve the ring seal, especially with your 150 shot. If you want to pass that C4 at the track, install one......afternoon project and no oil involved. It is not unheard of to pickup north of 30 horsepower with one, depending on current ring seal.
Jebby
Old Apr 28, 2020 | 09:43 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
When I was road racing and running short track I was experimenting with crank scrapers and could see a difference in lap times , so it got to the point where I never ran without one. When you are racing for money any little edge you can get , you do. Little time consuming to set up but not bad. Yes, you have to fit it to the rotating assy, but you just bolt it to the block with a couple bolts. Do each set of rods at a time. Max .050 clearance, I would not set it at .010. 025 to .035 is good. Bolt it to block, check it mark it grind , check again, repeat ,till you are happy. I am building a 540 BBC for drag racing now. It will have a scraper and I prefer the screen type windage tray. Smokey used to say a proper setup was good for 20 hp. I never had access to a dyno but saw the results on the track , so who am I to argue.
