Changing Trans Mount
Old Apr 30, 2020 | 01:24 PM
eddp's Avatar
eddp
Default Changing Trans Mount
Today's simple (yeah right, as if anything is simple) project is changing the trans mount. The plan is to loosen the mount to crossmember bolts. Jack the trans up just enough to remove the two mount to trans bolts and slide the old mount out and the new mount in. Question is: is the trans pan strong enough to hold the weight without denting or collapsing? See pic.
Old Apr 30, 2020 | 02:54 PM
MelWff's Avatar
MelWff
jack up the tail shaft of the transmission, I would not jack up the pan.
Old Apr 30, 2020 | 03:19 PM
derekderek's Avatar
derekderek
or a piece of plywood about the size and shape of the pan, so the load is on the sides, not the middle. but tail housing is best.
Old Apr 30, 2020 | 04:24 PM
eddp's Avatar
eddp
Tailshaft?? How? The crossmember is blocking the tailshaft.
Old Apr 30, 2020 | 07:28 PM
kanvasman's Avatar
kanvasman
2 X 4 the width of the pan, place it where it won't interfere with the next step of unbolting the trans itself. I used an old bottleneck jack and it made it easy when time to put it all back together, since the trans will probably shift to one side or the other a little bit. Just don't go too high because it's still connected to the engine. Good luck.
Old Apr 30, 2020 | 07:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
Tailshaft is not an option for a lift point. The board you have is the right idea. Like others said, just need a piece of plywood or OSB to distribute the weight evenly onto the pan, then the board under that. The pans strongest areas are the four corners.
You are lifting about a third of the combined weight. Use caution.
Old May 1, 2020 | 12:01 AM
7T1vette's Avatar
7T1vette
Solid wood piece as large at the bottom surface of the sump pan. No problem.
Old May 1, 2020 | 12:04 PM
MelWff's Avatar
MelWff
Didnt know you had the exhaust pipe in the way
Old May 1, 2020 | 08:59 PM
jackson's Avatar
jackson
Then put the jack against yoke or driveshaft.
To Changing Trans Mount
