Tach not reading above 3000
At first, it read really low, and didn’t read above 1500. I found that the tach filter was bypassed, so I rerouted everything to where it was supposed to be.
Now the tach reads correctly up to 3000. it starts to “trip” at 2500, and bounces between 2500-3000 when I gas it. Could it be a bad filter?
My tach stopped working. And I put a Willcox board in and it acted something like you describe. I just gave up on it. I recently put a little bigger cam in the car and to clean up the idle I put a new MSD 6 AL in and the tach started working perfectly. Willcox said I probably had a coil on the way out.cant say that's your issue but mine is working and it wasn't the likely suspect.
Update pt 2: drove around awhile. Tach works up to 3000 for about 20 minutes. Then it starts to droop, and eventually it stops working and holds at 500. After being parked for about 15 minutes, the tach worked again, but for only a few minutes, then drooping again down to 500. The zero set seems to change every time I turn the car off, and occasionally while driving.
As for putting the filter back in, perhaps it helped directly by filtering you some noise, or perhaps it helped just by unmating and mating the connectors which will clean the surfaces and lower resistance.
Lastly, there are other components in an HEI which degrade with age and like the coil winding are most likely to show this initially at elevated temp. Best test would be with a hand held tach you can hook up. If it gives the same results, then the problem is not the tach. An oscilloscope would also work, not that most people have one. I happen too (don't ask why) and the only useful thing I ever used it for was to verify that my Accel triple spark capacitive discharge module really produced triple sparks.
