1978 TH350 vacuum modulator
Old May 10, 2020 | 12:12 PM
78pacer's Avatar
78pacer
Default 1978 TH350 vacuum modulator
Where exactly is the modulator located? There's a delay between 2-3 gear when accelerating hard.
Thanks, Mike
Old May 10, 2020 | 01:07 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Back side of trans, passenger side, facing the rear.
Jebby
Old May 11, 2020 | 11:05 AM
78pacer's Avatar
78pacer
Thanks Jebby!
Old May 13, 2020 | 11:05 AM
lars's Avatar
lars
Keep in mins that most modulators have an adjustment screw inside so you can adjust the pre-load on the spring, thereby changing shift points. It can be adjusted with a small flat bladed screwdriver like this:
Lars
Old May 13, 2020 | 11:38 AM
wilcar's Avatar
wilcar
Thanks, Mike
Also check to make sure that the rubber mod vacuum hose going to the carb or intake is not pinched. I had a new 76 Trans Am that started shifting funny and was quite worried about it. Sure enough I had somehow pinched the ruuber hose when putting the hood scoop and air cleaner assembly back on.
To 1978 TH350 vacuum modulator
