A really really strange oil behaviour
The lifter in question seems to have failed internally. The rest are not suspect at this time. Lifter failures of this mode are very rare. Much more common to see the lifter bottoms fail and wipe out the cam. If you change all the lifters you have 15 additional unrequired opportunities to wipe out the cam. If you replace just the one lifter, your odds are greatly improved. You can buy a single lifter to make the repair.
There are some odds here but better than replacing all.....and when I was younger, I actually did it.....and it worked.
I use Moly Paste on flat tappet camshafts.....
Jebby
This additive with zddp is good? https://www.summitracing.com/parts/crn-99003-1
To install the new Lifter could I use this lube? https://www.summitracing.com/parts/hrs-msalube
I will buy 2 lifters. As said some posts above, I'll try to disassemble the first to use the components in the casing of the faulty one. If all went good, i can avoid problems regarding the breakin process. Otherwise I'll install the new one.
What do you think?
What do you think?
Jebby
MolyKote G-n Metal Assembly Paste 2076675 (has molybdenum disulfide, DuPont-MolyKote site indicates availability in Europe).
https://www.motionindustries.com/pro...p?sku=00785233
CMD Lube #3
https://www.cmdlubeoil.com/extreme-pressure-lubricant/
-add-
If this were my piece, I'd simply put a new lifter in it ... no worries IF one maker's or one production run's guts fit another maker/run.
What do you think?
Rather take a chance on a new replacement lifter and a slightly used cam would be my call on it.
Don't worry about breaking-in the new lifter bottom. Run it. Takes 30 min or less to create a pattern that matches the cam lobe. The lobe is already done.
If money were no object, I would swap all 16 lifters while the Intake is off. And all new "one-piece" pushrods IF, they were not installed.
We have heard way to many horror stories of people buying important components from EBAY. I would strongly suggest you stay away from the cheaper Chinese components that are being pushed on us today. The Chinese stuff is trash and I would do anything to keep it out of my engine.
I spent a lot of money rebuilding my 427 for my C3 and after it was broken in I drove it on a short ride when I started hearing a tapping noise that continued to get louder and louder so I went straight home. The next morning I discovered I had a Push-rod that was plugged which led to the destruction of my roller rocker arm on one cylinder. They were one piece rods and I was sure we had blown air through them before installing them. I bought another push-rod and a new roller rocker arm which took five minutes to change out. I was VERY lucky.
If it were my Corvette I would probably change out all 16 lifters for a known brand lifter kit. If one failed like yours did I would never trust the Engine again on long trips. You mentioned that the engine has a warranty so get them to replace all 16 with a better brand not made in China or India. I understand it would be more money but it will give you peace of mind while driving that beautiful Corvette on the roads of Italy. I wish I had a Corvette to drive on those incredible roads you have in Italy. I have heard that Edlebrock is using Chinese made parts and that some of the quality has gone down.
On my 427 the oil would be shooting out all over you with a valve cover removed... I took an old valve cover and cut a hole in the middle allowing me access but keeping me dry. Then I learned I had just cut up an original 396 valve cover that was worth several hundred bucks. Too Old too Soon, Too Smart too late...
Best regards,
Chris
P.S. Stay Healthy in this pandemic!
Surely the goal is to drive again my car, mostly because the pandemic lock down is mostly finished! Here in Piedmont where I live, there are the Langhe. A marvelous hilly area with some of the best roads (and winery) in Italy! Said so, I've been in the USA a couple of times, i drove for a total of 6000miles on some of the best and panoramic roads I ever seen!
Good luck.! You may want to mention to Edelbrock you are a forum member. It never hurts to let a company know you have the ear of thousands. The were always a good company but with Vic Jr gone it seems like the family has stepped back
Of course I knew there be some that oppose the lifter "repair".....so let me elaborate. Once you have it apart....the lifter needs to be disassembled and inspected thoroughly.....the foot, the bore inside, etc......if anything looks bad, then yes, it goes in the round file. In my experience though.......it is the one of the parts is actually missing from the inside......the check ball screen of the tiddly wink oil disc.......
So....if you check everything and inspect the lifter, then it is good to reassemble, assuming you found something and reinstall in the block. There is no reason why it wouldn't be......BUT, if I did not find anything wrong, then yes, replace it because deductive reasoning tells you to punt on this one......
My money? The spring under the check ball is broke....I have had this exact thing happen on a rebuild, and I fixed the lifter, it was fine after and is still running now.
Also.....what ever you decide to do, only coat the foot of the lifter with moly paste......the outer bore just coat with oil.......the reason is the paste is too thick and will hinder the lifter from spinning right away......it needs to spin immediately.....if it hangs up for any reason, it will grind the lobe off.
Jebby
