Electrical problem, maybe missing something obvious
Old May 20, 2020 | 04:05 PM
69ttop502's Avatar
69ttop502
Default Electrical problem, maybe missing something obvious
69 new dash harness, courtesy light door switches and headlight switch. Bulbs test good. Ok, rear dome light works as it should, both off the door switches, and by turning headlight switch all the way counter clockwise when the doors are closed. Neither front courtesy lamp lights up at all. Voltage present at all orange wires, including both courtesy lamp bulb sockets, lighter, clock and, again, rear dome lamp works as it should. Any ideas why the courtesy lamps won’t light up. Again, bulbs test fine. Probably missing something stupid but I am out of ideas. This is my first electrical test after buttoning up wiring. Doesn’t matter I am sure, but don’t have ignition switch hooked up at column yet, only turn signal harmonica connector. Thanks for the help.
Bill
Old May 20, 2020 | 05:12 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Well, if you have power, the bulbs test good. Do you have a proper ground? Not much else.
Old May 20, 2020 | 05:21 PM
69ttop502's Avatar
69ttop502
I assume if the ground was bad at either the headlight switch or the door switches, the rear dome light wouldn’t work correctly. Am I wrong to assume that. It is all the same white wire, correct?
Old May 20, 2020 | 05:24 PM
69ttop502's Avatar
69ttop502
My service manual says the #90 bulbs are correct for courtesy lamps.
Old May 20, 2020 | 06:57 PM
Richard454's Avatar
Richard454
Hey Bill-
is the headlight switch grounded?
here's a GREAT write up- THANKS Willcox!!!
Is part # 7 installed?
Old May 20, 2020 | 07:27 PM
69ttop502's Avatar
69ttop502
Well looks like it was something obvious. Even though my service manual says courtesy lights take #90 bulbs, a close look at the socket only shows 1 terminal and a 90 bulb has 2. Just shoved it in and didn’t notice. Found 631 single pole in my junk and it works. Some more digging says some that 631 is the right bulb. Oh well! Thanks for your help guys. Oh and yes I do have that little strap installed Richard. Your headlights are going in tomorrow!
Bill
Old May 21, 2020 | 10:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The door switches connect the ground when the door opens. The headlight switch connects the ground when you rotate it to the stop. When you install the headlight switch the locking nut grounds it to a metal strap and that tab gets bolted to the speedometer. Make sure that and the speedometer ground is connected. Picture of the ground strap
https://www.bing.com/images/search?q...cw=1117&ch=648
Old May 21, 2020 | 01:02 PM
69ttop502's Avatar
69ttop502
Thanks, yea got all that right, just made the mistake of following my manual and got the wrong bulbs. Put the 631’s in and all working perfectly!😀😀😀😀
To Electrical problem, maybe missing something obvious
