Torque Converter Question
As for what was in a '74 stock, good luck getting an actual number. I've been trying to figure out what was stock in my 80 L82 which should be a higher stall than the L48 given peak tq is 1000 RPM higher. But I can find no actual spec for it. Even on the TC which I've pulled, there are no markings which I can find which ID what it is and thus track down the stall. All it has on it is a TB7 that looks painted on, a stamped "CANADA" and a stamped "G03". I can find nothing that ID's the TB7 or G03 with a TC.
I do know that my cousin's '74 350 CI, TH400 tranny was crisp off the line and shifted well. It was the first car I ever drove any distance on the road. Got my permit a few months later
. 4 years later I drove it from NY to Las Vegas to deliver it to him after he moved. At night, t-tops off, cruising the Vegas strip, the reflection of the casino lights just flowing like water over the curves of a C3
. Those were the days.Good luck,
If you wish 'firmer' shifts, you would do best to install a "shift kit", as suggested above. I don't think that is needed, but if you prefer to feel all of the shifts made, so be it.
The 23-2500 rpm stall speed on the converter just means that when you are at a dead stop with brakes applied, in one of the forward ranges, and with accelerator pedal at WOT, the engine's rpm should be in that 23-2500 rpm bandwidth (if the converter was properly selected based on your engine's torque capability).
I'm a firm believer in you get what you pay for. Very efficient high stall converters don't even need the lockup function in modern lockup trannies. If you buy cheap crap you get what you paid for including the mind set that high stall means excessive heat. you bought junk. I used to have a dragster with a 6500 stall and at the end of the 1/4 mile after slowing down from 180 mph you took the return road and just drove back to your pits and then again up to the staging lanes. Massive stall doesn't mean that it doesn't drive well if you spend the money
The mentioned trans cooler is mandatory with any kind of loose converter, and is good practice.....especially in hot climates.
When you take it to the trans shop, have them check the hose for the vacuum modulator and the modulator itself.
The converter is like a hydraulic slipper clutch......the harder it has to work, the higher the stall will be. You have a 3.08 gear......the converter will have to "load" harder against that gear to move the car, which increases stall speed.......this also is the case with an engine that makes more torque or a heavier car.
I like mild stall converters because it gets rid of the "lurch' in gear at idle.......I don't like snappy shifts myself either, if the trans bangs into gear everytime, it is hard on components.....
But it is your car!
Jebby
But it is your car!
Jebby
to tell you the truth, I was a little disappointed at the overall performance. I wasn’t expecting a breakneck dragster but The motor seems to be carrying a load like it’s starting out in 2nd or 3rd gear. I appreciate everyone’s input and I’ll send updates hopefully as soon as Tuesday
