Long story short I had it a dealership that has a corvette guy. He found the distributor was not "aligned?" right (I had paid a guy to change it to HEI and then back to original) so he set the timing to what the emissions label said and adjusted the fuel and air screws.
When i left the dealership it was so sluggish it accelerating it was embarrassing so when I got home I nudged the timing up, knowing what my starting point was.
You would have to test which way the TCS solenoid worked. If it passes vacuum when not powered, you could just leave it all connected as is but not put the electrical connector back on the solenoid. If it blocks passes vacuum when powered, then you would need to send 12vdc signal to the solenoid at all times. Not too sure how that would work out long-term.
Found this. Energizing the solenoid pulls the plunger back toward the filter and opens up the airway.
So removing the plunger from one sounds like a fun project.
As opposed to just bypassing the solenoid which would be too easy to be called a project.
Anyway, timing light gets here Tuesday.
Something else to consider, with the hot weather it could be your coil breaking down. They don't last forever, and the heat gets to them. I had similar problems and the coil and fuel filter were replaced yesterday... Runs great now.
It's a new coil. I do think a bad coil was to blame for some issues I had that led me to try the HEI a few years ago.
Not exactly sure what the timing was on that hot day but now it's 16 initial, all in 36-37 @ 2600-2700 and I'm getting 15-16 vacuum advance so initial with vacuum is 32 and total with vacuum 52ish.
All of that seems to be within the parameters of Lars' suggested numbers.
Today I put initial down to 12 and took it for a drive and it did not respond well "off the line" so whether or not there is a hot start issue I think I'd rather have fun driving it and keep it in the garage on hot days if need be.
As to what it was set at on the day it wouldnt start- Because of the location of my vacuum advance canister hose and the distributor shield brace I can not go any more than 20 initial so I'm guessing I would have been at 18 when I nudged it up from 8 because I know I didn't have the hose touching the bracket.
Anyway, on different forums I've read that a hot engine is harder to start and an advanced engine is harder to start so it makes sense that it might not start in a perfect storm situation.
Still have half a tank of gas so have not got the ethanol free fuel yet but that is the next thing on my list.
By the way, I've driven it a couple times with the TCS out and it feels like someone dropped in an LT-1. Maybe a tired LT-1, but yeah, it runs nice.
It's amazing how much better it runs with proper timing advance isn't it?
Gotta love early GM emissions controls and their "retarded" timing! Or should i just say "retarded" emissions controls? LOL
