Hot start/Timing relation
Old Jun 3, 2020 | 08:07 AM
BarryB72's Avatar
BarryB72
Default Hot start/Timing relation
I drove my car yesterday not knowing it was around 90 degrees (no humidity, it was actually comfortable outside) and when got to where I was going , 20 minute drive, I felt a little drop in rpm, let's call it a sputter, when I pulled in the parking lot.
45 minutes later I started it with pedal to floor, no pumps, because I had flooding issues before I sent the carb to Lars but this was the hottest it had been since.
It started right up and ran for 10 seconds but even with trying to keep the idle up until it smoothed out it still died and the wouldn't restart.
It would turn over very fast, just wouldn't fire.
Got out and took the air cleaner lid off and there was a small stench of gas (of course?) and I let it air out for about a minute.
Got in the car and it started but it blew some white smoke that smelled like gas out tailpipe and after that it ran fine but when driving home if I would hit the brakes hard the RPMs would dip to 500 then raise back up to normal 800 idle.
My timing is advanced. It runs great. No pinging. Not sure the actual number though.
So, since 90% of carb issues is timing, COULD all of this have been different if I retarded the timing?
Old Jun 3, 2020 | 08:30 AM
Bikespace's Avatar
Bikespace
You should find out the actual timing number. Did you follow @lars' instructions for timing when you got the carb back? I would also check the engine temperature with a infrared thermometer shot at the upper radiator hose.
Get a baseline before you change anything. If your issues are due to high running temperatures causing vapor lock, retarding the timing is likely to make it worse, not better.
Old Jun 3, 2020 | 10:14 AM
BarryB72's Avatar
BarryB72
Long story short I had it a dealership that has a corvette guy. He found the distributor was not "aligned?" right (I had paid a guy to change it to HEI and then back to original) so he set the timing to what the emissions label said and adjusted the fuel and air screws.
When i left the dealership it was so sluggish it accelerating it was embarrassing so when I got home I nudged the timing up, knowing what my starting point was.
But I'll order a timing light.
Any suggestions on which one to get?
Old Jun 3, 2020 | 10:19 AM
Bikespace's Avatar
Bikespace
I really like my Innova 5568. You already know @lars, so be sure to follow his timing instructions.
Old Jun 3, 2020 | 11:23 AM
ClothSeats's Avatar
ClothSeats
White smoke is not gas. It is water. Excess gas causes black smoke, so it is very easy to distinguish the two. Have you noticed a drop in your engine coolant level?
Old Jun 3, 2020 | 01:24 PM
BarryB72's Avatar
BarryB72
No. Overflow tank level is right where I left it.
It was quick, I just caught a glimpse in my mirror and it smelled like gas.
Old Jun 3, 2020 | 07:03 PM
MelWff's Avatar
MelWff
Did the car originality have a fuel return line and it is no longer connected?
Old Jun 3, 2020 | 09:29 PM
BarryB72's Avatar
BarryB72
It did and it has one.
Old Jun 4, 2020 | 11:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It’s the fuel boiling, I had lots of issues, then added a 1 inch phenolic spacer and it went away. Now 1 inch is probably overkill and some folks don’t have the space for it. I would look for threads on fuel boiling and carb flooding on hot days, then see what the shortest spacer that works is. With ethanol it may be as thick as a half inch.
Another issue that could happen, but is an over night issue is the boil weeping gas through the case, but like I said that’s usually over night and is not heat dependant
Old Jun 4, 2020 | 12:26 PM
BarryB72's Avatar
BarryB72
It definitely boiled before I had the carb gone through.
Also found a heater hose touching the fuel pump to carb line.
This is the first time I've had this issue since I did those two things.
It's also the first time I've driven in 90 degree weather. I feel like I should have apologized to my car.
But the fact that it started up and then was so close to restarting made me think about timing because it does take a couple seconds to fire on a cold start versus instantly when I had the timing retarded.
Old Jun 4, 2020 | 03:10 PM
Rescue Rogers
Maybe it’s something as easy as the choke isn’t opening all the way and it’s flooding that way. Maybe it’s that?
Old Jun 4, 2020 | 04:47 PM
BarryB72's Avatar
BarryB72
I know this is a searchable question but I do t see a clear answer. what do you hook the cables to?
Old Jun 4, 2020 | 05:17 PM
Rescue Rogers
I ground on the nearest ground and take power from my alternator post. Then of course the inductor lead goes on number 1 wire. I just try and push the other wires away so there's no cross talk
Old Jun 4, 2020 | 05:26 PM
Bikespace's Avatar
Bikespace
There is a clamp that goes on the #1 spark plug wire. 12V power comes from the back terminal of the alternator (+) and the engine (-). If you don't have HEI anymore, the green clamp connects to the negative side of your coil.
https://csr.innova.com/Content/Manua...ual_5568_E.pdf
Old Jun 4, 2020 | 05:40 PM
BarryB72's Avatar
BarryB72
I see why you like it. It's rated the best timing light.
Old Jun 9, 2020 | 05:08 PM
BarryB72's Avatar
BarryB72
I bought a timing light. It's just a timing light. Nothing fancy.
Anyway, I look at the timing tab and it goes from 8 before to 8 after.
With a basic light how do you even tell what your timing is beyond 8 advanced?
Do I need to make my own marks on something to be able to simply check my timing?
First timer. Except I think I watched dad use a timing light 35 years ago.
Old Jun 9, 2020 | 05:52 PM
ckirsch100's Avatar
ckirsch100
Active Streak: 90 Days
Lars from the forum here has authored papers on setting up the timing.Email him and he will send them to you.He’s a great guy just ask.
To Hot start/Timing relation
Old Jun 9, 2020 | 06:02 PM
Bikespace's Avatar
Bikespace
You can save yourself a heap of trouble by buying a digital timing light with dialback, like the Innova one above.
Otherwise, you will need to mark your harmonic damper. For example, with MSD 8985 tape.
Here's a video that may help. They use the same MSD tape.
Old Jun 9, 2020 | 07:27 PM
BarryB72's Avatar
BarryB72
Yeah, I think I'll just send this one back.
Old Jun 10, 2020 | 12:00 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Rabbit trail question... why are you so concerned about temperature? 90 isn't all that hot in the scheme of summertime temps. Just curious where the cautiousness comes from.
