My Cross-breed Drive Train
Old Jun 10, 2020 | 01:23 PM
C3TPI's Avatar
C3TPI
That is exactly what I am planning. Cut a poly mount down to size. I cannot use any conventional mount because of the location of the trans mounting bolts. They are too far to the right and too widely spaced. All I need is a piece of poly or dense rubber to go under the aluminum pillow block. A piece of exhaust hanger strap might even work. I'll report back with what I come up with.
Old Jun 10, 2020 | 04:59 PM
C3TPI's Avatar
C3TPI
So I dug through my junk box (you know, that one you though everything into you might need some day), and found a piece of high density black rummer 1/2" thick and fashioned a pad 3" X 2" to go between the aluminum pillow block and cross member. The trans now has enough side to side flex to prevent anything from cracking. I only lost 1/2 degree of tail shaft angle, so I still have 2+ left. That's about where the diff pinion angle is, so all's good there. On to the exhaust!
