Speedometer Accuracy Issues...Driven Gears
Old Jun 16, 2020 | 10:16 AM
Z06CE's Avatar
Z06CE
Originally Posted by 7T1vette
You need fewer teeth on the driven speedo gear to make the speedometer read 'faster'. For the amount of error you have, I would go with 3 fewer teeth than what you have now.
These gears come in "sets". For each 'drive' gear, there are several 'driven' gears that will work with it; and each drive gear MUST have driven gears within a specific range of teeth. You can't go any more or less than what the drive gear will allow. I'm pretty sure that you can get a 19 tooth driven gear for your 'set', but you need to research that to be sure.
When I went from 22 teeth to 18 teeth the speedo went slower. Whats going on? Unless there is a problem with the drive gear.
I went back to the 22 teeth gear and the speedo reads faster.
Old Jun 16, 2020 | 11:30 AM
MelWff's Avatar
MelWff
From 4.56 to 3.31 the Drive gear is 6261794.
Starting with the 3.08 and down the drive gear can be 3924099 or 6261794. The majority in the second group are the 3924099. So you may have the wrong Drive gear for a 3.08.
The 3924099 was superseded by 3905494.
Old Jun 16, 2020 | 11:34 AM
Z06CE's Avatar
Z06CE
Its looking that way. Thanks for the help
Old Jun 16, 2020 | 11:51 AM
MelWff's Avatar
MelWff
The 794 is 8 teeth natural color plastic.
The 494 is 9 teeth steel.
Old Jun 16, 2020 | 12:34 PM
7T1vette's Avatar
7T1vette
Think of it this way: with a [drive] worm gear turning a fixed speed, a mating [driven] gear with 12 teeth will take longer to make one revolution than a gear with 10 teeth. So more teeth on the driven gear will slow down the speed; less teeth will make it go faster (higher MPH).
I suspect that the 18 tooth gear was below the acceptable range for your drive gear. You just need to crawl under the car, remove the speedo gear 'bullet', and use the mirror to see what color the drive gear is. If the gear you have will accept a 19 tooth drive gear, that will improve the speedo accuracy without having to pull the trans tailshaft.
