Speedometer Accuracy Issues...Driven Gears
Old Jun 14, 2020 | 04:01 PM
Z06CE's Avatar
Z06CE
Default Speedometer Accuracy Issues...Driven Gears
1969 Corvette Muncie 4Spd
I have a 3.08 differential, 27" tires, and using a gray 22 tooth driven gear. My speedo is reading 40 mph but actual is 47mph.
When Speedo reads 60 mph the actual is 71 mph verified with gps.
I purchased a driven gear set ... 17 tooth to 22 tooth, I tried using the brown 18 tooth driven gear but made the speedometer read slower... 25 mph when actual was 50 mph, so 2 x the error. So I went back to the 22 tooth driven gear.
The kit didn't have 23 tooth gear... what can I do to get the speedo accurate?
Old Jun 14, 2020 | 04:11 PM
Big2Bird's Avatar
Big2Bird
Ideally, the gears are used to set the odometer accurately, and the "head" is calibrated to that. 1000revolutions per mile.
Old Jun 14, 2020 | 04:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
You can never get a speedometer to read 100% accurate. So, you should always have it error on the high-side. It keeps you from getting (more) tickets.
Any time there is a drastic change in rear axle ratios, the "Drive" gear must be changed also. For example, going from a 4:56 rear to a 2:78.
Your speedo is off quite a bit, but I think its correctable by studying ratios at Speedometer World web site.
I could be wrong, but I think you need less teeth on the driven gear to spin faster.
Old Jun 14, 2020 | 04:32 PM
Z06CE's Avatar
Z06CE
Thats what I read but tbe speedo read slower....I tried going from 22 to 17 tooth and speedo read 2 x slower..crazy.
Old Jun 14, 2020 | 05:09 PM
john 72-04's Avatar
john 72-04
it is my understanding that one tooth on the gear equals approximately 1.5 MPH...….if that helps you. Speedo reading too fast use a gear with more teeth. Too slow.....less teeth
Old Jun 14, 2020 | 06:08 PM
HeadsU.P.'s Avatar
HeadsU.P.
Try TCI Automotive (speedometer world). They have calculators, gear color codes, tooth count, etc.
Hope that a correction can be done easily at the trans driven gear. If you have to swap out the Drive gear, not a fun job. Involves driveshaft / tailshaft housing removal.
Need small hands to unclip old gear, slide off of tailshaft, etc, etc, etc.
Old Jun 14, 2020 | 06:22 PM
MelWff's Avatar
MelWff
Exactly what size try do you have, 225/70x15 etc.?
Have you actually counted the number of driveshaft revolutions per 1 tire revolution to confirm the 3.08?
The 22 tooth gear is used for 3.55 and 3.73 depending on tire size.
Old Jun 15, 2020 | 10:02 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Here’s a thread with some links. Thegearbox.org has gears with more teeth but it could be a problem with the drive gear. Some tranny have plastic gears and they can slip....just a thought.
https://www.corvetteforum.com/forums...post1601465889
when you scroll down there’s a calculator for figuring what should work
Old Jun 15, 2020 | 10:48 AM
7T1vette's Avatar
7T1vette
You need fewer teeth on the driven speedo gear to make the speedometer read 'faster'. For the amount of error you have, I would go with 3 fewer teeth than what you have now.
These gears come in "sets". For each 'drive' gear, there are several 'driven' gears that will work with it; and each drive gear MUST have driven gears within a specific range of teeth. You can't go any more or less than what the drive gear will allow. I'm pretty sure that you can get a 19 tooth driven gear for your 'set', but you need to research that to be sure.
Old Jun 15, 2020 | 10:56 AM
7t9l82's Avatar
7t9l82
California performance transmissions has a speedometer corrector you take a reading at an indicated 55 miles an hour on your speedometer and read what the GPS on your phone says and they will make you a box that will correct the speed
Old Jun 15, 2020 | 04:59 PM
7T1vette's Avatar
7T1vette
Big money, compared to changing a driven speedo gear. But, that is an option.....
Old Jun 15, 2020 | 05:01 PM
7t9l82's Avatar
7t9l82
the other option is jacking the car up getting under their taking the gear out counting the teeth putting it back in putting the car back down ordering the gear putting it in after jacking the car up again this way all you do is Jack the car up once put the bucks in put the car down done you pay for convenience
Old Jun 15, 2020 | 05:14 PM
7T1vette's Avatar
7T1vette
Everyone has to do what they think is best. You have adequately provided the detailed options for the OP.
BTW, removing that gear takes about 10 minutes and 1 wrench.........
Old Jun 15, 2020 | 08:14 PM
7t9l82's Avatar
7t9l82
I totally agree it's a very simple operation either way.
Old Jun 15, 2020 | 08:58 PM
Z06CE's Avatar
Z06CE
Tire size is 255 60 15
I have a 3.08 gear. I recently went from a 3.90 to a 3.08 differential.
There was a gray 22 tooth driven gear in the tail shaft.
actual mph was higher than the speedo . See 1st post..
I purchased a driven gear set and tried a Brown 18 tooth gear. At 50mph actual the speedo then reads 25mph! so the speedo read slower with the lower tooth gear.
Old Jun 15, 2020 | 09:07 PM
MelWff's Avatar
MelWff
There is no 3.90 listed for a 69 4 sp.
For the 3.08 the only driven gear listed is the 18 tooth brown gear.
Can you see the drive gear, is it damaged or slipping?
Old Jun 15, 2020 | 09:16 PM
Z06CE's Avatar
Z06CE
Someone other than me installed the 390 with the 22 tooth gear. I didnt like the 390 when I purchased the car. Thats why I put the 308 in the car. I think the speedo is out of calibration.
To Speedometer Accuracy Issues...Driven Gears
Old Jun 16, 2020 | 09:56 AM
HeadsU.P.'s Avatar
HeadsU.P.
Just for clarification, the "Drive Gear" is mounted on the tailshaft. It drives the Driven Gear which has easy access at the end of the cable.
The Drive Gear is more difficult to swap out.
I believe there are only a few Drive gears to cover a wide array (dozens) of Driven Gears choices..
You really need to know the tooth count on the Drive Gear so you know what you are dealing with. It is possible to count the teeth of the Drive G. with a flashlight in the hole.
Tough, but doable. You can also rotate the driveshaft if the tires are off the ground and count that gears teeth.
Old Jun 16, 2020 | 10:08 AM
Z06CE's Avatar
Z06CE
Yes I understand about the drive gear vs the driven gear. I must have the 1.84" diameter because the tail shaft accepts the smaller diameter 17-22 tooth driven gears. What I don't know is the tooth count for the drive gear.
Old Jun 16, 2020 | 10:10 AM
Z06CE's Avatar
Z06CE
I haven't been able to see the drive gear. I have to jack the car up and try to use a mirror to see the drive gear.
