Coolant change
Old Jun 16, 2020 | 10:47 PM
DWAVette's Avatar
DWAVette
Default Coolant change
Recently got an all original 82CE.
Changing all fluids to get a baseline.
current coolant is bright green.
Should I convert over to the orange Dexcool? (That is what my 2013 6.2L called for.)
Old Jun 16, 2020 | 10:50 PM
interpon's Avatar
interpon
I dont think so at least for a 79..i bought dexcool and removed it went back to green advised from a lot of folks here..i think because aluminum in newer engines and if exposed to air acidifying..
Old Jun 16, 2020 | 11:00 PM
Big2Bird's Avatar
Big2Bird
The green has worked for 40 years. Why change?
Old Jun 17, 2020 | 06:33 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
stay green.....green coolant matters
Old Jun 17, 2020 | 06:34 AM
Bikespace's Avatar
Bikespace
Dexcool for your LS motor, green stuff for your C3.
Be sure to pull the plugs on the block and flush everything well. I couldn't believe the gunk I got out of the engine when I did this.
Old Jun 17, 2020 | 06:50 AM
Engage's Avatar
Engage
Change it but stay with the green....... why look for trouble?
Old Jun 17, 2020 | 07:33 AM
Rescue Rogers
If any brown sludge comes out of the engine block drains, I would definitely buy some system flush and drive around with it in there for a day, then drain it. I did that and my system came out squeaky clean
Old Jun 17, 2020 | 10:17 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I remove Dex-Cool from any old GM product I work on.........its service life is much shorter and tends to turn to gel if left in the system too long. If I were to drain and flush the cooling system in my 11' Silverado LS, I would replace it with green.......
Dex Cool was created around 1996 for S-Blazers that overheated at the Arizona proving grounds as a 11th hour "fix".........there is zero benefit to having this **** in your Corvette.
Down here a mix of distilled 75% and straight green anti-freeze 25% is the ticket....up north, 50/50.
I want to add that "coolant" is anything but.....it is a misnomer, "coolant" doesn't help cool anything. Straight distilled water is the second best liquid to use next to alcohol, and we all know that we can't use alcohol. It has to do with reducing the boundary layer on the inside surfaces of the coolant passages to improve thermal transfer.......coolant actually makes the boundary layer thicker. I have worked on Hot Rods here in Texas that cooling issues were solved with just replacing straight coolant with 75% water.
Jebby
Old Jun 17, 2020 | 12:20 PM
DC3's Avatar
DC3
There has been some good discussions in years past on this forum about what type of anti-freeze to use. The consensus from one of the discussions about 10 years ago was to not use Dexcool in our older vehicles. Among the known issue of breaking down and turning to gel, there is a chemical in Dexcool and other OAT solutions which can soften any gaskets or seals that may contain silicone. Because of the discussions I mentioned, I've been using Zerex G-05 in my '73 without issue for the last 10 years or so. I use a 50/50 mix as my part of Texas has hard freezes.
DC
Old Jun 17, 2020 | 12:41 PM
7T1vette's Avatar
7T1vette
Engine Materials
In addition to the specific composition and color of the two coolants, DEX-COOL is designed specifically to interact with aluminum engines. Unless a previous owner has used traditional green coolant in your vehicle, using DEX-COOL for an aluminum engine will help minimize corrosion.
Old Jun 17, 2020 | 01:06 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by 7T1vette
Engine Materials
That might be so....but using distilled water and fresh green anti-freeze will damn near last forever. Just ask a savvy L-98 C4 owner.
Jebby
Old Jun 17, 2020 | 07:51 PM
DWAVette's Avatar
DWAVette
Default Thank all of you
What a great response for a newbie. I appreciate all the answers.
It seems this is the agreed best for my 82:
Zerex G05.
I live in south Louisiana. I think it hit 32 once this winter for a few minutes, but it can, occasionally, drop in the lower 20’s.
What mix, 50/50 distilled water or 25 coolant/75 distilled?
Old Jun 17, 2020 | 08:01 PM
Bikespace's Avatar
Bikespace
You should be able to get away with 25% coolant 75% distilled in that case. Is that Zerex pre-mixed, or concentrate?
Old Jun 17, 2020 | 09:25 PM
DWAVette's Avatar
DWAVette
Good question - It’s concentrate.
Old Jun 17, 2020 | 10:29 PM
7T1vette's Avatar
7T1vette
Use Zerex or Prestone glycol coolants and distilled water (about $1 at grocery stores)....50/50 mix will protect in hot or cold weather.
Old Jun 18, 2020 | 12:01 AM
68blvert's Avatar
68blvert
The problem with original dex-cool was lack of maintenance. Dex-cool has a service life of around 5 years. After that it becomes acidic and will start to eat stuff it touches. It needed to be flushed and replaced as it reached 5 years in service. I've seen the internal GM TSB stating as such. The new formulas of dex cool doesn't have this problem. The gel problems was the result of electrolysis to dex cool being used past its service life. That being said, why go through the expense of using dex when green works just as well in these old gals. On a side note, of all the coolants I've dealt with the Toyota red keeps the inside of it's engines CLEAN. Worked on Toyo's that looked like they came off the ocean floor but the insides of the coolant passages were spotless. Like the block had just been poured the day before.
Old Jun 18, 2020 | 11:22 AM
Mrvettenick's Avatar
Mrvettenick
50/50 has a higher boiling point, and corrosion protection. I wouldn't go lower than that.
To Coolant change
Old Jun 18, 2020 | 11:59 AM
ctmccloskey's Avatar
ctmccloskey
I too have rid my vehicles with the red DexCool anti freeze. I would keep the green style anti-freeze in it.
Down where you are you probably don't need to much for your winters. In Virginia I use 70% distilled water and 30% anti-freeze as the water transfers the heat more efficiently.
Replace the radiator cap if it looks old, I replace mine on a regular basis to avoid problems. same goes for the thermostat
Old Jun 18, 2020 | 02:03 PM
Gunfighter13's Avatar
Gunfighter13
I recommend using Evans. No water no corrosion no sludge from car sitting.
https://www.evanscoolant.com/
Old Jun 18, 2020 | 02:15 PM
DC3's Avatar
DC3
Probably good stuff but I'll have to pass on a $250+ coolant change. Actually more the first time since you have to prep and flush the system of the old coolant.
Zerex G-05 and distilled water will set me back less than $50 total considering NAPA currently has it on sale for $13.99/gallon.
DC
