1978 Ignition Problem
Old Jun 18, 2020 | 06:53 AM
weschedc's Avatar
weschedc
1st Gear
Default 1978 Ignition Problem
Got in our 1978 Corvette last night. Turned the ignition on. She cranked a few times, sounded normal, but didn't start right away. Turned the key off and tried again but nothing - no clicks or anything. Sounded completely dead. Battery seems fine. Any thoughts? Fuse? (Where is that) Ignition switch? Any suggestion on where to start would be helpful and appreciated!!
Old Jun 18, 2020 | 07:58 AM
Edward Ackley's Avatar
Edward Ackley
1st i would check battery to make sure post ae clean and tight, 2nd i would try to jump start or use a battery charger with a start setting next i would go to the starter (that happened to me)
Old Jun 18, 2020 | 02:33 PM
hunt4cleanair's Avatar
hunt4cleanair
Also...check ground cables, especially the one off the starter. If the cable is frayed, it will present like a dead battery.
Old Jun 18, 2020 | 08:00 PM
7T1vette's Avatar
7T1vette
When you get NOTHING (no clicks, etc), you either have a starter solenoid that is kaput, a misadjusted or failed neutral start switch, or some [related] electrical wiring that is not making connection.
To 1978 Ignition Problem
