Tachometer problems...
Old Jun 20, 2020 | 05:10 PM
Daveinspain's Avatar
Daveinspain
Obsessed
2025 C3 ('68-'73) of the Year Finalist - Unmodified
Default Tachometer problems...
All of the sudden I started getting erratic jumping around on my tachometer although the engine runs smooth. Checked the tach cable connections in the engine bay. It has a short extension cable that’s connected to the distributor. Then that connects to the cable that enters the firewall going to the tach. I haven’t been able to check the cable connection at the tachometer. Weird observation, the tachometer works fine when the engine is cold.., Once it’s warmed up the tach starts going erratic or just drops to 0... Any ideas???
Old Jun 20, 2020 | 06:14 PM
MelWff's Avatar
MelWff
Factory had a single cable something is set up incorrectly.
Is the vacuum unit on your distributor almost parallel to the firewall?
Old Jun 20, 2020 | 07:14 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you may have a broken tachometer cable, I just broke mine today.....but mine stays at zero...
Old Jun 20, 2020 | 09:40 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Perhaps you lost the link and connection to the last time you pursued this:
https://www.corvetteforum.com/forums...see-video.html
I replied this, did you get a chance to check it?
That's odd. I know the speedometer cable can be a two-part assembly but never heard of the tach cable being that way.
Before tearing into your dash, disconnect the tach cable at the distributor. You should be able to spin it by hand and not feel any binding. If you do feel something, disconnect the cable junction you mentioned above and try it with the cable section coming from the firewall. You could test the tachometer itself by spinning the cable with a drill. I don't recall the necessary direction, so use a reversible drill. Make sure the needle isn't bouncing around when the drill is at a steady speed.
I'd be really curious to investigate this two-part tach cable arrangement.
Old Jun 21, 2020 | 09:27 AM
Daveinspain
Obsessed
I’ll post pics...
Old Jun 21, 2020 | 02:17 PM
7T1vette's Avatar
7T1vette
I would suspect a problem with the connection between the two cables. The ends of the cables are 1/8" square drive. If the frays or wears, it will drive no more.....even though it is spinning. The tach head has a worm gear which might be worn out. I would try the cables first, before digging into the "pit of DOOM" behind the dash pad....
To Tachometer problems...
