Broken strut rod bracket
Old Jun 27, 2020 | 06:09 PM
80vette21's Avatar
80vette21
Default Broken strut rod bracket
I brought my car in to work today to install my new 18s and line it up after installing my VanSteel coilovers in the front. Unfortunately while I was under it, I found my VBP strut rod has a huge stress crack! I'm planning on gutting the rear next winter to rebuild the rear end and do Vansteel coilovers back there, but in the meantime I need to fix this so I can get back on the road.
Obviously VBP is out of business, so I can't go to them. I know Vansteel has these brackets, but does anyone know if their bracket will fit the VBP strut rods? Are the strut rods a standard size? I'd rather replace only the bracket if possible... It'll be much faster, and I don't want to waste time /money when I'm going to be gutting it in a few months.
I appreciate any advice!
Here's the damage :
On the bright side, I love the jump from 15" Torq Thrust to 18". They came out great, however I had one wheel that was showing a ton of roadforce. I managed to get it down to a somewhat reasonable level, but I think it may be a bad rim. I may have to try to get it replaced, not sure how much luck I'll have with that though.
Old Jun 27, 2020 | 06:41 PM
MelWff's Avatar
MelWff
How about an original OEM style bracket?
Old Jun 27, 2020 | 06:48 PM
REELAV8R's Avatar
REELAV8R
How about taking it off bending it straight and welding in some reinforcement steel as a fix until you replace it all. Seems that would be cheap enough if you have a welder. Even if you don't it should be cheap enough. Don't know how that would compare to the cost of replacing it as melwff suggested.
Old Jun 27, 2020 | 07:22 PM
80vette21's Avatar
80vette21
That's not a bad idea. Vansteel's bracket is $99 I think, so if that would fit it'd probably be worth just getting that. I think I'll be able to reuse this strut rod setup with the coilovers anyways.
Old Jun 27, 2020 | 07:28 PM
Big2Bird's Avatar
Big2Bird
You need a plate to back that bracket up. Too much stress the way it is.
Old Jun 27, 2020 | 09:27 PM
80vette21's Avatar
80vette21
I just talked to a buddy of mine who is a welder and does custom fab. He said I can drop it to him and he'll repair and reinforce it.
Does anybody know the removal process for just the bracket? Can I just disconnect the strut rods and drop the bracket? Should the car be up in the air, or can I do it on the ground?
Old Jun 27, 2020 | 10:21 PM
TimAT's Avatar
TimAT
It will be easier up in the air so you can get to it..But yes, just remove the bolts for the strut rods, then the 4 that hold the bracket to the housing. Pay attention to which way the braket is on the housing- mine are not square and the bracket only fits one way. And as usual, if it's not correct, only the last bolt won't go in..
Old Jun 28, 2020 | 01:05 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Originally Posted by 80vette21
... I found my VBP strut rod has a huge stress crack! I'm planning on gutting the rear next winter to rebuild the rear end and do Vansteel coilovers back there, ...
Here's the damage :
Sure not a good advertisement for VBP even if they are no longer in business...
Paul
Old Jun 28, 2020 | 07:37 AM
derekderek's Avatar
derekderek
i was thinking "gee. i wonder why they went out of business..." put a plate between the bracket and the diff and it will have nowhere to bend to. OEM. ebay. 40 bucks. https://www.ebay.com/itm/Original-GM...8AAOSwylhcCoE- yours is batwing?
Old Jun 28, 2020 | 09:17 AM
80vette21's Avatar
80vette21
Thanks Tim. I wasn't sure how much the strut rods actually supported the wheels and if they could just be removed without supporting the wheels. Sounds like it's straightforward like I was thinking.
Paul
Not at all. I also just had one of my calipers from them fail after 4yrs. I opened it up and found it was leaking at the seam between the two halves because it had been poorly machined during the rebuild.
Mine was a batwing. I converted to a pre 80 rear-end setup a few years back for added strength.
Old Jun 28, 2020 | 11:04 AM
carriljc's Avatar
carriljc
That's what I would have done. And box it while I was at it. Even if you have some concern about weight boxing it in would be a good idea. Drill a couple of holes with a holesaw in the bottom for access to those bolts and you'd have a better than new product.
Old Jun 28, 2020 | 11:07 AM
carriljc's Avatar
carriljc
BTW - those 18" wheels look fantastic. Not too busy some gaudy things I've seen.
80vette21's Avatar
80vette21
Good idea. I'm pulling it out today or tomorrow and dropping it to my buddy to weld...I'm mid-move and my welder is deep inside my moving POD at their storage facility! I asked him to repair and reinforce it, I'll mention what you said about boxing it in.
Old Jun 28, 2020 | 11:20 AM
derekderek's Avatar
derekderek
https://www.ebay.com/itm/1975-1979-C...MAAOSwdYFeo0eQ https://www.ebay.com/itm/1968-1974-C...wAAOSwmjdeoz2p
Old Jun 28, 2020 | 11:21 AM
carriljc's Avatar
carriljc
and show us a pic when he's done ..... we like pics
Old Jun 28, 2020 | 12:32 PM
80vette21's Avatar
80vette21
So I guess my main question was will the aftermarket VBP strut rods fit in other brackets... IE are the strut rod end diameters universal? Based on the responses that a factory bracket would work, I'm guessing they are?
Old Jun 28, 2020 | 02:36 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
I have a used one for 15.00 where do you live ???
To Broken strut rod bracket
Old Jun 28, 2020 | 02:55 PM
derekderek's Avatar
derekderek
you r&r the bracket whether reinstall fixed one or replace it is gonna affect the rear wheel alignment.
Old Jun 28, 2020 | 03:53 PM
80vette21's Avatar
80vette21
I'm in Burlington. You have a used stock bracket? Are there any downsides to using the stock vs aftermarket? Does the stock have the same adjustability with the concentric bolts? Also, I'm not sure the VBP strut rods will fit in the stock bracket, although the consensus seems to be they will
Yeah I had planned on doing a 4 wheel alignment after doing the wheels/tires, because I just did the front coilovers, but then found the crack. I still plan on doing a real thorough 4 wheel alignment once I fix the bracket.
Old Jun 28, 2020 | 08:02 PM
ralphspears
Banned Scam/Spammer
Yes it is a stock used bracket not rusted in good shape
