front light/rear lights issue
Old Jul 5, 2020 | 05:10 PM
corvettedave383's Avatar
corvettedave383
Default front light/rear lights issue
Hi guys, ive got a new issue, looking for some help - 78 C3
My front lights wont come on, so thought get a new light switch, which did not help, so what ive discovered, if i remove the rear light fuse the front lights will work, but if i put the fuse bank in, rear lights work, but front lights wont come on, I unplugged the socket from the light switch and hot wired it if you know what i mean, used a piece of wire to see if same thing happens and it does, so its not the light switch, something back in the loom or a relay ??
anyone with any ideas?
cheers
Old Jul 6, 2020 | 07:50 AM
henrikse's Avatar
henrikse
Are we talking headlights or parking lights? Sounds like no trouble with rear so focus on front park or headlamps. Get yourself a wiring diagram and a test light or meter and follow the circuit from source to light. If we are talking front parking lights ensure your grounds are good and pigtails are clean.
Old Jul 6, 2020 | 08:46 AM
derekderek's Avatar
derekderek
ground missing. so the other lights act as a ground path.
Old Jul 6, 2020 | 09:10 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
second the bad ground
Old Jul 6, 2020 | 04:07 PM
corvettedave383
so i take it the ground will come into that light switch, so focus on that ground 1st?
Old Jul 6, 2020 | 05:32 PM
Rescue Rogers
theres multiple frame grounds throughout the corvette being fiberglass and all. Each light housing has a ground to the frame through the harness as well as the tach, speedometer, radio housing, center console, gauge console, etc.....IF one isnt grounded well the electricty can search for apath to ground through another component making act wonky
Old Jul 6, 2020 | 06:44 PM
derekderek's Avatar
derekderek
and the big ground? engine to block? if that is missing the starter can fry stuff trying to crank thru every light in the car.
Old Jul 6, 2020 | 06:50 PM
corvettedave383
thats all good there, has an extra one
Old Jul 7, 2020 | 08:48 AM
derekderek's Avatar
derekderek
there won't be a ground at switches. they are hot in and hot out. the ground is where the electricity is used. the lights, motors, etc... reversible motors like windows may be different. they sometimes use 2 hots. sometimes switch hot and ground at the switch to reverse direction.
Old Jul 7, 2020 | 09:14 AM
Rescue Rogers
the headlight switch is grounded so when you rotate the **** to the stop it contacts the ground and turns on the courtesy lamps. THe 68 wiper switch is supposed to be attached to the center console that acts as a ground as well even though the plug has a ground wire... Willcox diagrams says 69 and newer wiper switch also must be grounded
Old Jul 13, 2020 | 02:22 PM
corvettedave383
Update - problem fixed, spiced into the front sidelight/turn signal earths, earthed everything at these points to the front chassis, all sorted
thanks for everyones help
To front light/rear lights issue
