69 Radio help
Old Nov 27, 2002 | 05:43 PM
telk's Avatar
telk
Default 69 Radio help
Got radio working but there is a constant humming sound coming from the speakers. its very noticable on fm and somewhat on am. Any ideas why?
Thanks Telk
Old Nov 27, 2002 | 06:03 PM
WHTSHARK's Avatar
WHTSHARK
Default Re: 69 Radio help (telk)
It humms because it doesn't know the words :lol:
Happy thanksgiving
Old Nov 27, 2002 | 06:55 PM
parttime's Avatar
parttime
Default Re: 69 Radio help (WHTSHARK)
blown speaker?
Old Nov 27, 2002 | 07:16 PM
69stingray's Avatar
69stingray
Default Re: 69 Radio help (parttime)
blown speaker?
OR, just plain poor reception. The radio is 30 something years old.
Old Nov 27, 2002 | 09:29 PM
Clink69's Avatar
Clink69
Hum is usually from bad ground. Could be external(wire) or internal (such as a bad capacitor). Does the hum change with RPM?
Chris
:flag
Old Nov 28, 2002 | 12:22 AM
telk's Avatar
telk
Default Re: 69 Radio help (Clink69)
Car is not running at the moment. But reception gets better when I touch the exterior antena
Old Nov 28, 2002 | 01:09 AM
Juliet's Avatar
Juliet
There is a condensor on the coil which acts as an aid in radio ignition suppression. Is yours in place? The fact that things change when you touch the antennae makes me think you might need to check for a bad ground somewhere in the system.
Old Nov 28, 2002 | 04:38 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: 69 Radio help (Juliet)
Check up under the rear of the car. Look for the large metal "ground plane" which should be mounted under the antenna. Also, look for the antenna ground strap. It should run from the antenna base to a bolt on the frame. Also, check to see if the antenna is fully plugged into the side of the radio. If it still hums, it just might need a pro to rebuild it. Many companies specialize in rebuilding antique auto radios. Hope this helps. Chuck
Old Nov 28, 2002 | 09:29 AM
woodsman's Avatar
woodsman
Default Re: 69 Radio help (Chuck Gongloff)
Try isolating it to whether the noise is internal to the radio or external to it, i.e., move the car and see if flourescent light or motors in the area are causing the noise. Also, remove the right side trim panel and connect a spare antenna mounted to a ground plane (isolated metalic base) to see if it is an antenna problem. Most likely one or more electrolytic capacitors (the biggest ones in there) have deteriated. Electrolytics have a limited life span and are said to deteriate faster if they are not occassionally repolarized by being powered up. Otherwise, most of the other components including transistors should last a life time unless hit by lightning or static electricity. Good luck
Old Nov 28, 2002 | 10:47 AM
telk's Avatar
telk
Default Re: 69 Radio help (woodsman)
Thanks I"ll start checking those things soon.
Old Nov 28, 2002 | 10:49 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
With it NOT running that would not matter.
Old Nov 28, 2002 | 11:56 AM
Juliet's Avatar
Juliet
Default Re: 69 Radio help (SanDiegoPaul)
That depends on if not running means engine not running at all, or if he just can't drive it around the block to another location to see if reception improves elsewhere. :D But yeah, I see your point. :) ~Juliet
To 69 Radio help
