Tri Power Throttle Response Issue
1) He has only owned this car for a year.
2) "When the throttle is released, the rpm drops back to the idle setting slowly rather than quickly as it seems it should."
3) From OP: "The throttle returns to the idle stop quickly via the throttle spring, but the drop in rpm significantly lags (about 2 seconds). The rpm does not hang up at the high level then drop suddenly to idle; it just drops at a slow consistent rate, back to the idle rpm."
So, we have determined that the RPM does return to idle, just not as fast as the OP thinks it should.
- How much experience has he had with older cars?
- How fast does he think it should return to idle?
- What RPM is he releasing the throttle? Is the delay proportional to RPM or the same no matter what.
- Automatic or manual. Clutch in or out. OP mentions "This happens whether you're just snapping the throttle by hand in the driveway, or actually driving the car (so independent of load, throttle cable, secondaries, etc.). " but behavior will be way different if driving, then release throttle, then clutch in.
- What is "about 2 seconds"? 1.2 seconds, 2.0 seconds, 2.5 seconds? RPM dependent?
Lots of variables here and as a test engineer, they all need to be understood and minimized.
The tri-power system has vacuum operated outboard carbs. They are engaged at the fuel flow rate that the engine can consume without choking on it. Since they are not strictly 'mechanically' actuated, there is a short delay in those carbs getting reset to fully closed position. Most of that is by design, so that the engine does not see a NO FUEL condition at high rpm's. Lots of tri-power systems have mechanical actuating systems (ie, progressive linkage) which can close completely in the time it takes the return spring to shut them off.
Install the WOT actuation system you wish to have.....
Thanks for the reply, good questions. A few answers:
- I have owned three muscle cars (hemicuda, Super bee and now BB vette). I'm not an expert by any means but I am familiar with old cars.
- my expectation is the rpm would return to idle in typical fashion, based on my experience, meaning without a noticeable lag.
-In the driveway, when I snap the throttle, I release it at about 2500-3000 rpm.
- I have not conducted a rigorous analysis, but I'd say the behavior is very similar whether I snap the throttle in the driveway, or drive the car, accelerate, and quickly switch into neutral. The rpm slowly returns to idle. It may be a little slower when driving the car, but it clearly happens independent of the car being in gear.
-By "about 2 seconds" I mean more than 1.2 seconds for sure, more like between 2 and 3 depending on how high I rev the car.
I've tried to minimize the variables by analyzing the issue in the driveway (independent of clutch, opening secondaries, etc.)
Great points. I agree completely that the vacuum secondaries would close slower than mechanical secondaries and I should expect some inherent lag. however, this lag I'm seeing is independent of any secondary opening (in the driveway, no load, I stare at the secondary linkage and there is no movement, I also completely disconnected the secondaries and no change)
