1971 ls5 ac
Old Jul 12, 2020 | 11:14 AM
thelal1's Avatar
thelal1
Default 1971 ls5 ac
Replaced all o rings, had cooler condenser repaired, new return tube from dryer, compressor checked. AC works fine when jumpered out. Then located diseling relay, changed it. No change so put a jumper wire in AC works fine. Ordered a New blocking relay next to it. If that doesn't work any info would be appreciated. By putting a jumper wire in on terminals for anti diseling relay works fine but doesn't have max blower speed.
ted
Old Jul 12, 2020 | 11:28 AM
7T1vette's Avatar
7T1vette
Nice list of stuff you have done. What is the problem, specifically? If MAX blower speed is your problem, that HI speed is separately fused with an "in-line" glass fuse. It is located in the engine compartment near the brake master cylinder. Look for a large orange power line with an integrated fuse.
Old Jul 12, 2020 | 12:51 PM
thelal1's Avatar
thelal1
Default Fuse
That fuse is fine. With the metal cover off the blocking relay, if I manually get the contacts to make contact, max blower speed comes on. Does dieseling relay work in tandem with blocking relay. They sit side by side on blower box. I know blocking relay is bad. When I took its cover off it contained lots of rust.
To 1971 ls5 ac
