Reverse on ‘77 with 350 trans
Old Aug 2, 2020 | 03:14 PM
San Diego Ron's Avatar
San Diego Ron
Default Reverse on ‘77 with 350 trans
When shifting into reverse, hesitates and slips (sometimes about a minute) before clunking into gear. Not low on fluid but that is what it acts like.
Old Aug 2, 2020 | 07:10 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey Ron,
This is pretty common with the Turbo 350 and 400 if they've sat for a length of time. The rear piston seal dries up and when the car is fired up it doesn't seal well so fluid slips by before shifting into gear. Depending on how bad it is, I have had good luck using an automatic trans conditioner like Lucas, etc. to soften up that rear piston seal. It may take 200-300 miles of regular driving before it does the job but once it works, it works. Certainly worth a try before going to all the trouble of pulling the trans for an overhaul.
Cheers, Greg
Old Aug 2, 2020 | 07:48 PM
HeadsU.P.'s Avatar
HeadsU.P.
Greg is right. And the amount of sitting time is unpredictable. Sometimes after a week, sometimes after a month. For my TH350 the outside temp effects operation too.
Its just a matter of idling a minute or two, then the tranny grabs. No further issues the rest of the day.
Old Aug 3, 2020 | 10:04 AM
San Diego Ron
Thanks guys, that is most likely my problem, car does sit sometimes a month or longer, seven vehicles in household of two is overkill, really need to sell off some of them.
Old Aug 3, 2020 | 11:39 AM
7T1vette's Avatar
7T1vette
Just a 'double-check'...
The auto trans fluid is checked hot with engine running and in drive range. If you fill it with engine OFF to the fill line, the trans will be low on fluid when running.
Old Aug 3, 2020 | 03:43 PM
HeadsU.P.'s Avatar
HeadsU.P.
Not sure that's a good idea unless you trust your parking brake.
Every GM I have had says: running, on the level, warm, in park.
To Reverse on ‘77 with 350 trans
