Tie rod adjustment
Old Aug 8, 2020 | 12:31 PM
BarryB72's Avatar
BarryB72
Here's the pitman armName:  photo441.jpg
Old Aug 8, 2020 | 09:57 PM
7T1vette's Avatar
7T1vette
Oops! It's only 6"....
Old Aug 9, 2020 | 06:01 PM
Mooser's Avatar
Mooser
So if it's 6 then it's 8.4 deg instead of 7.2 for 1/2 turn of the sleeve, instead of your .4 it's closer to .3 type of thing.
Drive it around the block to make sure it's still tracking and back it off "some"
M
Old Aug 10, 2020 | 06:20 PM
BarryB72's Avatar
BarryB72
I'm at .35 of a turn now from the first photo of the steering wheel and it is really close now.
But I had the leaking charcoal canister after I got home from my test drive so I haven't been able to fine tune it yet.
What I noticed was the farther off the steering wheel was the more correction I had to make to drive straight and it was always turning the wheel in the direction that it was off to keep it straight.
Last drive the wheel was almost straight and I actually had to adjust the wheel both directions (but maybe 3 to 1 on which way I had to go) to keep it straight so I feel once the steering wheel is straight the steering will be centered as well.
Old Aug 10, 2020 | 07:25 PM
7T1vette's Avatar
7T1vette
The irony is that your steering wheel is almost never 'straight' when you are driving..
Old Aug 19, 2020 | 04:19 PM
BarryB72's Avatar
BarryB72
Got the steering wheel straight but then I realized that the flat spot on the steering box shaft was not at 12. More like 12:05-12:10.
Then I remembered when I had the steering column out that the coupling on the steering column end had about one spline of adjustment...and that's what it needed.
Tie rod settings, here they come. Right back where they started from.
Old Aug 21, 2020 | 04:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
Cant you move the steering wheel over a spline or so?
Old Aug 22, 2020 | 12:05 PM
BarryB72's Avatar
BarryB72
I read some old posts that said the hub had adjustment to it but I had never pulled a hub.
