Without actual alignment readings adjusting the tie rods will center the steering wheel but the question is why is it off center.
To center the wheel you will need to lengthen the passenger side tie rod sleeve over all length and shorten the driver side tie rod sleeve. Start with 1/2 turn each side.
Now if you are interested in checking your alignment read this.
Steering box was rebuilt. I planned on an alignment from my mechanic but it goes straight down the road with the wheel here and had an alignment done a few years ago.
Your roads must be flatter than the ones around here
tie rods are 5/8-18 (I think) so 18 threads per inch = .055" per thread turn
pitman arm is something like 7" long (I'm guessing)
One turn on the tie-rod would be (math) .45 degrees on the box
standard box is 16:1 so .45 on the output times 16 is 7.2 degrees on the input
7.2 deg on a 15" steering wheel is (math) 9.4 out at the top
So 1 turn on the tie-rod would be about 1" off on the steering wheel at the top
ish.... ?????? (there's a lot of guess-ishs in there and I'm still on my second coffee...)
coffees have already worn off so take this with a grain of salt...
.055" moved the 7.2 degrees, when you turn the tie-rod sleeve both ends move in/out the same amount so 1/2 turn on the sleeve would move each end out .0275 (x2 = .055) , and whatever you do on the one side you need to undo on the other side so it still tracks/toes the same. Does it seem that you need to move the wheel roughly an inch to correct it?
M
So would a half turn on each side result in 7.2 degrees total?
If So I would need .416 of a turn on each side.
I think.
Originally Posted by Mooser
...whatever you do on the one side you need to undo on the other side so it still tracks/toes the same
Mooser is telling you the most important step. It doesn't really matter how much or many turns you do, just make sure to do the opposite on the other side. Turn one side 1/2 turn one way, turn the other 1/2 turn the other way and check steering wheel alignment. If not enough, do more; if too much, back off from what you did.
I think another important point to make is to carefully monitor how the car tracks down the road and steers in general when you're finished. If it pulls to one side, then it needs to be realigned. Also, over the next few hundred miles, pay attention to tire tread wear to make sure a setting isn't off and causing scrubbing of the tire against the road surface.
No. And the direction of rotation for each side needs to move both wheels in the same direction. Since the OP needs to turn a bit to the left for the car to go straight, BOTH wheels need to be adjusted so that they point more to the LEFT. So the right tie rod adjustment needs to 'extend' that rod further, while the left one needs to be shortened by the same amount. (1/2 turn to start, IMO)
Give it a little bit of a drive and over some bumps, etc. before you go after it again. Things have to settle back into place. Once it seems stable (and that may already be the case), make your fine-tuning move.
Was that a 1/2 turn or between 1/2 and 1/3?
Also, when your in there again, can you check the length of the pitman arm? I'm curious if the 7" guess was close enough.
Also also, make sure you have even turns on the wheel lock to lock, the zero position needs to be on the high spot of the steering box so it needs to be in the middle of the full left vs full right
M
