Reproduction alternator/power steering brackets
Old Aug 10, 2020 | 09:32 AM
Big Block Dave's Avatar
Big Block Dave
Default Reproduction alternator/power steering brackets
Hey fellas....long story short, Ive got a broken lower power steering pump bracket on the 454 in my 74. I may also be looking to replace the adjuster bracket for the ps and alt, as Im missing the rearward bolt hole that goes to the exhaust manifold/header.
Are the reproductions of these parts good, or has anyone had more headaches with these pieces not lining up properly etc?
Thanks for any input.
Old Aug 10, 2020 | 09:57 AM
rberman999's Avatar
rberman999
On my 73 SB 350 I used the Paragon aftermarket power steering bracket set (sold as a kit). I had no problem with them. Lined up perfectly. Note: the SB uses a different bracket set than the BB. Just giving you my experience with my situation. Good luck, Russ
Old Aug 10, 2020 | 09:39 PM
Joe79Vette's Avatar
Joe79Vette
Paragon has the right parts and they fit. I bought a few of their brackets when I was putting a 427 in my 72. The fit was perfect. Everything lined up.
Joey
Old Aug 11, 2020 | 06:55 AM
Big Block Dave
Thanks that’s the kind of info I was looking for. As much as I’d rather have original brackets, since they should fit properly, at least I don’t have to scour eBay searching for parts they have probably been repaired or crazy expensive NOS stuff.
Old Aug 11, 2020 | 01:39 PM
7T1vette's Avatar
7T1vette
If you have a correct stock bracket that is broken, you can weld it up or replace it. In general, buying replacement parts is a 'crapshoot': it might LOOK like stock...it might not; it might WORK like stock...it might not. I will ALWAYS save an original part, if I can.
Old Aug 11, 2020 | 06:55 PM
Big Block Dave
in this case, the lower is probably repairable, but based on where it’s broken, a repair might interfere with the way the pump fits in the cradle. The other piece, well it needs to be replaced, but your sentiments are exactly what leave me hesitant about Repro bracketry
Old Aug 12, 2020 | 01:52 PM
7T1vette's Avatar
7T1vette
Just passing what I believe is a 'useful' strategy..
To Reproduction alternator/power steering brackets
