1981 Rochester Carb replacement
Stumbling when I start, little to know starting power, smell of gas if I punch it. I know I could use a rebuild but figuring maybe its time to just replace it. Remember I live in California so I'm somewhat limited. Also, don't want to dump a bunch of cash on this so looking for something resasoable.
Let me know your thougths.
the computer thingy that tells your car how to run and in some cases how to shift.
Lars
Jebby
The factory manual is very easy to follow, and you don't need any special tools other than a volt-ohm meter and the ability to read the flashing codes from the check engine light. For me the hardest part was locating the test connector under the ashtray and inserting a screwdriver in the correct slot to tell the ECM to flash the codes.
Any old-school mechanic can rebuild your carburetor, but it has t be tuned on the car as part of that process, and that requires connecting and reading a volt meter. Lots of guys get all in a tizzy with that last part, but it's really no big deal. The only caveat here is that in order to adjust the throttle position sensor the rebuilder will need to drill out an aluminum plug that prevents monkeys from playing with the tiny adjustment set screw. That's not unlike the idle mixture screws (which are also plugged by the factory). Then use blue Locktite to keep the screw from backing out.
Lots of guys will tell you to just toss it and go mechanical but the other thing that the computer does for you is adjust the advance on the distributor. It also locks up the torque converter. Since you have the misfortune to live in The PRC you will also need it for the emissions functions. Since I happily live in a state that respects my freedom and my old cars I was able to remove most of that junk that tends to make the engine run poorly and pollute more.
The easiest way to check to see if the ECU is working is to unplug the four-wire connector to the distributor. Set your timing at 6 degrees BTDC and then reconnect it while the engine is running. It should advance the distributor quite a bit, off the factory scale. Then do the same thing to the carburetor. Remove the passenger side electrical connector, start the engine and listen to the carburetor. Reconnect it while the engine is running and you should be able to hear a faint but steady clicking sound, several times per second, which are the mixture needles bouncing up and down.
My ECU was burned out when I got my car. When that happens the carb runs full rich, and then that clogs the single catalytic convertor. I diagnosed my ECU fail through the factory manual. A rebuilt one took a day to get to me, over the counter at Autozone for $82.
Now I know that 20 people on here have 81's that run fine......it is when it doesn't.....one year only distributor and carb that is almost unobtainium would make me swap this stuff out before it quits. It is not because the 81' didn't run right new.....it just has almost zero support, is not conducive to ANY upgrades short headers/exhaust...maybe an intake....and the distributor curve map is pathetic.
In the case of the OP's car.....you can stick a Idle Control Solenoid in it but the chances that it will quit again are high....they are not an easy part to find anymore and most are "rebuilt".
I am one of those "right guys" that you could take your car to.....and I say fix it if you want......but change it all out if you can.
Jebby
From my point of view, if the car has not been in a flood or a fire which could do major damage to wiring and electronic items, 40+ year old wiring should be deemed 'serviceable' until it is found not to be so or if it can't pass simple visual inspection judgement. Those who just pull out wiring because it is OLD could be wasting their money, if the wiring isn't presenting any obvious problems. If someone is doing a complete restoration and they choose to replace wiring and electrical items at the same time, that is certainly appropriate action. IMO, discarding functional items which are not exhibiting problems is likely a waste of time and money. I would not discard any 'factory' parts for today's reproductions for ANY REASON other than significant part wear, damage, malfunction or safety risk. Just being OLD doesn't fall into any of those categories/
but hey, I'm running EFI on my 77. And yes it runs great. And if it takes a **** in 10 years. I'll bet there will be an even better system to replace it with.
40 year old wiring, 40 year old computer controlled carb?
certainly there is a better fix.
Just my honest opinion.
All carb and smog parts are available with exception of diverter valve and EGR control solenoid.
Quadrajetparts.com has all the parts.
DUI has new distributors.
In Ca. you are allowed to upgrade to a newer engine IF you transfer all related smog equipment to the car with the transplant.
