1982 L83 Idle
1) I thought these usually fire up to about 1K rpms until warmed up and then settles in ~550. Mine only sometimes ramps up to 1k during warm up. AC on or off. It surprised me recently that it seemed to do this once or twice. Idle Air controllers? TPS maybe? Idle at start up just seems intermittent a bit in its behavior. But, it idles nicely smooth at ~550 when warm. Rare for it to die during start up. It hunts a little, but stays short of dying.
2) I notice there is actually a choke light in the cluster, but never have ever seen it come on? Is it supposed to ever come on indicating a warm up condition? Only when it's cold outside and the choke actually comes on?
3) I read in another thread about a choke relay in the center console. Symptoms of it going bad?
Thoughts?
Got an OBD I scanner coming to dig a little deeper.
If the IAC's are old.....it may need new ones too....remove and inspect these.
The choke light has no bulb in it.....GM's way of saving money.
Jebby
Jebby
Also hook a vacuum gauge to a port.....does it bounce or is it steady? Bouncing indicates a leak.
Jebby
Thoughts?
Jebby
Your best course of action would be to download any stored trouble codes via BOTH methods to see how they compare and to identify any system problems recognized by your ECM. Any improper operation of the engine management system should be logged and identified in the ECM. If you have stored trouble codes, they will guide you as to what area of the system to look or test for specific deficiencies. If there are NO stored trouble codes, you still could have some 'issues' caused by engine control sensors that occasionally provide faulty signals. But, no logged trouble codes would indicate that the 'significant' components in your system are operating properly and that issues would be likely related to sporadic sensor readings that confused that system for an instant.
Now, this is all based on the fact that the CEL is working on your dashboard. When you put the key in the ignition and turn it to RUN (but not START), all the indicator lamps on your dashboard should light. You want to be sure that the CEL is 'on' when ignition is in 'run' mode. Then, when you start the car, the CEL should turn "off", which would indicate that the engine management system is working properly. If you never see the CEL light come 'on', it is most likely that the bulb is burned out OR someone has disconnected it. You need to get that lamp working to be able to download trouble codes via your OBD-I connector and CEL light flashes.
Also, have you even checked your TPS sensor for the proper voltage? Easy enough, key ON, engine off, check for .525vdc. If not, set it as close to that as you can. It will want to wonder a bit as you tighten the screws so just compensate for that and tighten as you go. Also, after you set the TPS, check for smooth operation of the TPS through its entire range. SLOWLY moving the lever which it a wiper inside the TPS, if there is any spot that goes OPEN (which is a dead spot) on your DVM or wild reading, the TPS is probably bad. Recheck it several times and see if you can duplicate the reading n the same spot(s). The TPS is important. It tells the ECM where idle is by throttle plate position. When you start a cold motor, your idle should be around 1,300ish rpm or slightly higher and then drop as the engine starts to warm up and go to idle setting.
One last thing, there are NO separate choke systems like on a carb for a CFI engine. The choke is controlled by the ECM and is a fixed setting in the PROM for a cold motor start. After the motor is warmed up, the sensors on the motor take over and feed the ECM data to control the motor correctly. The 81 was the last engine to have a carb and choke system along with the Gen I ECM system. CFI is Gen II, OBDI.
Re-post back on what you find. Thanks and good luck.
And, as I mentioned before, download those codes using the 'paper clip' and via the scanner. The codes could be different; but all codes collected should be 'relevant' to your problem.
or the ^%*& ecm according to the FSM (unless I have a ground in the wiring somewhere that I'll never find).
