Another aerodynamics question
Old Aug 26, 2020 | 12:35 PM
JC 1975's Avatar
JC 1975
Default Another aerodynamics question
I have been very cornered about heat build up in the engine compartment. On a hot day the temperature gauge would get up to 220 (I do have a pretty heavy duty aluminum radiator with electric fan) and the front fenders would be hot to the touch. I do have non coated headers on the car. On a whim, I decided to cut out the wall on the back side of the factory cowl hood to let in low pressure cool air. And good news! The temp gauge now doesn’t go over 200 degrees, even in 95 degree heat. Bad news! The car starts to have what feels like a bucking motion above 75mph.
So what did I screw up??
I was thinking about installing hood vent to remove more heat and reduce under hood pressure.
Old Aug 26, 2020 | 01:31 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Guys do get these to run cool without hood mods.
  1. Make sure all your rad seals are there and tight.
  2. Make sure lower lip spoiler is there.
  3. Make sure your elec fans have a shroud that covers 100% of the rad.
  4. Get your engine timing corrected per Chevy Power Book or Lars. Not factory. Engine runs much cooler. Recurve distrib and run on manifold vac advance. Final settings somewhere around 12-16 degrees initial, may vary, but way more than factory 4 or 8. Maximum centrif advance must be 36 degrees period, and it should be a all-in around 3000. Vac advance (on manifold vac) should add only another 10 degrees, may need to be restricted. You will not believe how much better and cooler it runs.
  5. Get headers coated inside & out. Do not use wraps that will rust them out.
Old Aug 26, 2020 | 01:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Vents make sense to me, less hot air in there the better. Your bucking has nothing to do with the hole you made, wonder if youre going lean?
What rpm is it happening? Can you duplicate it in N? (detecting a slight miss)
Old Aug 26, 2020 | 02:16 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Would checking the thermostat be prudent? (I believe most Corvettes specify the 160-180 rating range.) If there's a 195° or 200° thermostat installed won't the engine temp not drop below that when fully warmed up?
Old Aug 26, 2020 | 04:38 PM
JC 1975's Avatar
JC 1975
I haven’t changed anything with the engine. It’s running good. Too good to where I pushed the car a little too hard. I can definitely feel a buffeting effect. The hood was shaking like it wanted to open. I also forgot to mention that I have lowered down to 26” at the front wheel wells so maybe air is getting trapped?? It wasn’t doing this before I lowered it and cut a hole in the back of the hood. So I’ve messed up the aerodynamics some how.
Old Aug 26, 2020 | 04:53 PM
JC 1975's Avatar
JC 1975
Ha! Lower lip spoiler- The wind ripped that off a couple of days ago.
Coated headers is definitely on the list for future mods.
Old Aug 26, 2020 | 05:05 PM
ctmccloskey's Avatar
ctmccloskey
I have a 1968 C3 with the 427 and four speed. That car has no problem going above 100 mph and exhibits no buffeting either. At above 130 the C3 under full power the C3 has a Front End "Lift" problem. Even with my 427 it still lifts the suspension at higher speeds. The Indy spoiler sure makes a huge difference when attached properly.
Old Aug 27, 2020 | 12:17 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Is it going up and down or side to side? If it’s a fast left to right bounce in your Wheel it could be a bump steer situation and I think if you lowered the front end you may be changing the caster or camber of your wheels just enough to create this issue. I was experiencing the same thing and raised my front from 26.75 to 27.25 and it went away.
If it where an air flow issue underneath the car you would feel like the front drifts or wanders down the road. I’ve had that feel on old big boat cars (68 Mercury Montclair) at high speed and week shocks that felt like a boat rolling across waves drifting during a lane change
also,what is you sidewall height of your tires and the air pressure? If it’s to low and you have taller 15inch tire the sidewalls could be collapsing and wallowing if your running below 28 psi. I have tall thin tires on my f250 and when a tire gets low you can really feel it.
Old Aug 27, 2020 | 02:25 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
My money is on this.......
Ceramic coated headers lower underhood temps pretty dramatically......the temp at the pipe is reduced to more than half.
Jebby
Old Aug 29, 2020 | 11:14 PM
JC 1975's Avatar
JC 1975
It was more of a wind buffetting feeling. I have a new front chin spoiler coming and if that doesn’t work hood vents are next. And if that doesn’t work I’ll look into the suspension.
I did check the tires and the air pressure was good. I didn’t check the balance of the tires. That could be part of the problem.
Old Aug 29, 2020 | 11:33 PM
7T1vette's Avatar
7T1vette
Well, opening up the cowl created a lot of turbulence at the base of the windshield, I'm sure. What you are feeling could be a combination effect of the cowl and front air dam issues.
Old Aug 30, 2020 | 07:57 PM
Rescue Rogers
wind buffetting at 75mph sounds more like a suspension issue versus a aerodynamic effect. I have a 68 that had little to no cowl on the front and a L88 hood and what ever air got under there would go out the hood or the side vents. I added a bigger air dam for cooling and its smaller than the full spoiler you can get it helped with the cooling. Prior to that the only issues I felt were above 100mph. I would look towards suspension issues or have someone drive next to you and see of they can spot any issues when you feel it happening
To Another aerodynamics question
