ignition
Old Sep 4, 2020 | 12:46 PM
planet-automobile's Avatar
planet-automobile
Default ignition
I bought a car at auction but I have a problem with the ignition
​​​​​​I have 12 volts
but no ignition
problem with the distributor
Old Sep 4, 2020 | 12:53 PM
GordonR's Avatar
GordonR
1st Make sure the pink wire is tested for 12 volts while the engine is cranking. 2nd Unplug the "tach" connector off the distributor and try it again. If a no go your will have to diag the unit.
Old Sep 4, 2020 | 12:59 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Delete
Old Sep 4, 2020 | 01:02 PM
wilcar's Avatar
wilcar
but no ignition
So you are saying that you have 12 volts at the pink wire but when you plug it into the cap you have no spark when turning the engine over? Could be that old accel coil or the ignition module. Greg
Old Sep 4, 2020 | 03:56 PM
planet-automobile
Ok
I will do that
Old Sep 5, 2020 | 06:35 AM
planet-automobile
I did a cleaning
Old Sep 5, 2020 | 06:51 AM
GordonR's Avatar
GordonR
Did you take a look on the center backside of the rotor itself also? Common when going bad to pass the high voltage from the coil straight into the dist shaft.also. Its appearance will be a blackish crack.
Old Sep 5, 2020 | 09:06 AM
planet-automobile
I changed the distributor cap, the car start
probably a problem with the Ignition Coil
To ignition
