More Quadrajet help please (long)
Drain out all of the old gas, as the owner of a '71 LS5 for the past 45 years that I have barely driven for the past 30 years, I've experienced the problems with old gas. It would barely run, miss, pop, etc. New fresh gas and it smoothed out. Now I keep it filled with ethanol free gas and use it in my lawn equipment, then replenish with new gas as needed. I start it up at least once a week and drive it around the block.
But yes, 10-15 is a good start for initial timing with no vacuum advance engaged.
My problem (among others) is that the engine won’t run AT ALL without that much initial timing. That has me stumped as well. I’ve tried with and without vacuum, obviously setting without, light springs, heavy springs, completely locked. I wish I could remember how I had it set the first time I owned this car. But I’m sure it wasn’t like this. And to reiterate, I did check the TDC mark using a stop. It’s just weird.
I made up three new wires and took it for a drive and amazingly it ran pretty good. Still a little down on power, but likely due to my 6 year old gas and having tuned the carburetor while only firing on five cylinders.
I had a feeling I’d be slapping myself when I finally found the issue, and I am. I had put these nice MSD wires on it probably ten years ago when I owned it the first time. Apparently during the time it was under another’s care he had been a bit forceful in removing and reinstalling the wires.
So, I’m embarrassed to say I did miss something simple. Thank you all for taking the time to walk me through my stupidity.
Tom.
I started out being absolutely positive that my problem was ignition related. But after checking (or so I thought) EVERYTHING in the ignition system all I had left was the fuel system. Stupid thing is that I’ve literally had 75 or more cars in my life. I may have had two bad plug wires create a problem along the way. One for sure, but maybe two. I’ve literally NEVER encountered three bad wires on a running car. Ever! I can’t believe it ran at all. It just goes to show you that buying a car that had been disassembled by someone else requires checking everything as it goes back together.
By the way, if you don't want to wait out your timing tape and don't own a dial back timing light, you can make marks on your balancer by wrapping a piece of string around it, finding the circumference, and then marking the string at the appropriate degrees. IE if you have a 6" balancer, the circumference is (pi * 6), 18.84". (10/360) * 18.84 = 0.52". So make a mark about 1/2" from the TDC relief on the balancer and you'll have a 10* marker.
More info here: https://www.crankshaftcoalition.com/..._a_timing_tape
I do have a dial back light. My biggest problem right now is that the timing tab is basically buried behind the idler pulley. At 60 years young it’s all I can do to lean my fat butt over enough to see my zero mark.
Since you seem to know your stuff.... whenever I set up a curve I generally time by the maximum advance at around 34° to 35° (without vacuum) then let the initial fall where it may. If too low I’ll shorten up the advance travel. I generally limit vacuum to about 10°. I’m certainly not racing but I’m not wanting to leave potential power on the table when it comes to the tune. Am I in the ballpark or should I rethink my norm?
I'm glad it worked out, and was something simple to fix, if not diagnose!
Find the bolts holding the pulleys on the balancer, or maybe you can see the keyway. Check the relationship of those to your "zero" mark on your balancer.. If it's close you should be good. If it's off, it's probably way off. Your 30 degree mark got me thinking about this.
Glad it has been mostly easy fixes so far!
Sounds like bubba took care of the car after it left your care
OK here is a fresh pic. Looks like one of the 3 pulley bolts lines up almost exactly in a straight line with TDC and the balancer retaining bolt. Lucky for you my engine stopped at almost exactly TDC, (It is at 4 after.) This is a new degreed balancer where I painted over most of it. It is not a tape.
I actually did one better and checked the TDC with a threaded piston stop tool. The TDC mark is right on the money with the indicating tab. Had I been thinking (or remembering) I’d have installed an adjustable pointer and moved the TDC mark up higher so that it’s more visible with the timing light. But... coulda’, shoulda’, woulda’... One day when I need to get the radiator out or do some other front work I hope to remember to do that.
So pinch it off with some vice grips for a min and watch the rest of your
problems go away.
It's a wide open vacuum leak. OBD motors use idle air control.
Ours don't.
So I purchased a paint gun pressure reg at harbor freight.
Installed it inline before the PVC.
Dialed it down to a nice idle , and still pulled neg pressure.
Then start turning screws.
Hope that helps.
ramair in calif. (as we burn to the ground)...............
keep looking up and smiling.
problems go away.
Ours don't.
Hope that helps.
problems go away.
Ours don't.
Hope that helps.
Thank you all for your suggestion that got me this far.
get out more..............
