Electrical issue
Old Sep 18, 2020 | 09:10 AM
Stuart Nevills's Avatar
Stuart Nevills
5th Gear
Default Electrical issue
I have an 82 corvette. Someone had installed an aftermarket alarm system into it. When I had it repainted I had the body shop remove it. Now ever once and awhile I will be setting at a stop light and when I hit the gas the whole car shuts down. If I let off quick enough the electric kicks back in. If not I have to start the car again and it seems fine. Any suggestions.
Old Sep 18, 2020 | 10:00 AM
ClothSeats's Avatar
ClothSeats
Is it just the ignition that shuts down, or do other electrical components shut down as well? If so, specify which, i.e. interior lights, headlights, radio, heater fan, etc.
Old Sep 23, 2020 | 07:23 PM
Stuart Nevills
5th Gear
the whole electrical system. I had to connectors that were melting. One under the hood and one behind the cluster. Cut them out and replaced them. All good now.
Old Sep 24, 2020 | 02:48 PM
SwampeastMike's Avatar
SwampeastMike
Are you certain it was an aftermarket alarm system? The '82 came with a standard alarm system that was reasonably sophisticated and included ignition kill.
To Electrical issue
