carburetor filter paper
Old Sep 25, 2020 | 08:33 AM
fake's Avatar
fake
Default carburetor filter paper
Is the check valve in the paper filter for if you roll over it shuts fuel off and i noticed a couple N.O.S. with no check valve
Old Sep 25, 2020 | 09:07 AM
drwet's Avatar
drwet
Yes we used to call that a roll-over valve. It was common to remove the guts from them as they were believed to be prone to causing problems. Don't know if they did or not, but that's what everyone did.
Old Sep 25, 2020 | 09:27 AM
fake's Avatar
fake
yes i believe you are correct it could get hung up and give a restriction on fuel flow also. Thanks dewet
Old Sep 25, 2020 | 02:03 PM
Sayfoo's Avatar
Sayfoo
I think the valve also helps prevent fuel running out of the carb once the car is shut down.
Many people prefer this one vs the one without the valve.
Old Sep 25, 2020 | 02:14 PM
71chimera's Avatar
71chimera
^^^^ THIS ^^^^
aka anti-siphon
Old Sep 25, 2020 | 02:19 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Check valve one prevents bleed back....but flows less. Non-check valve unit flows more but the bowl will drain. Most who run the check valve type will never notice it.
Jebby
Old Sep 25, 2020 | 02:50 PM
fake's Avatar
fake
Thanks gang and that includes Jebbysan
To carburetor filter paper
