master cylinder
Old Oct 6, 2020 | 02:11 PM
malutki515's Avatar
malutki515
Default master cylinder
help
I just finish replacing and bleed my brakes. all new lines ,hoses, calipers and master cylider.
when I pumping brake pedal fluid perculate in front chamber , nothing happening in rear chamber .
is this normal or I have an issue
thank you
Old Oct 6, 2020 | 02:28 PM
Dynra Rockets's Avatar
Dynra Rockets
nothing should be "percolating". Did you bench bleed before installing?
Old Oct 6, 2020 | 02:37 PM
malutki515's Avatar
malutki515
maybe I describe better. when pumping brakes I have small fountain of fluid raising in fron chamber . nothing in rear. is that maybe because I keep front of the car higher than a back when working on brakes bleeding?
Old Oct 9, 2020 | 10:39 PM
SharkAttack's Avatar
SharkAttack
Did you bench bleed the MC to where you saw no air bubbles in the front or rear chamber and also saw a small "fountain" of fluid in both the front and rear chamber? When bench bleeding, use slow strokes and don't exceed 1" of travel. Also, I have found that using plugs in the ports is more effective than hoses that go into the chambers.
Old Oct 10, 2020 | 03:48 AM
hunt4cleanair's Avatar
hunt4cleanair
Put another way, you have air in your system that, more than likely is locked into the master cylinder and why you are asked if you had bench bled the M/C. As noted...it should not be percolating.
To master cylinder
