Voltage Drop @ AC compressor connection
Old Oct 18, 2020 | 09:18 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Voltage Drop @ AC compressor connection
Voltage Drop Question:
Hello Forum.
I am restoring my AC in my 68 BB and coming into the home stretch. I checked my battery voltage at the terminals and I have 12.4 volts. At the pig tail for the compressor connection of the stock wiring I have 10.6 volts.
The AC position is on in the console, fan set on Hi, and temp set to cold.
I ran an auxillary black ground wire from the grounding point on the compressor bracket to the ground point on the fan relay as the new compressor housing in aluminum.
Is this about right with the car not running to have 1.8 volt drop?
PS: I pulled a deep vac and have a leak some where? So now I will add some R134 for leak test purposes and get my sniffer going. I can then locate the leak, correct and pull a vac and recharge with R-12.
Any and all comments welcome.
Thanks,
Marshal
Old Oct 18, 2020 | 09:23 AM
henrikse's Avatar
henrikse
If the car is not running and you have the key on there will be resistance and voltage drop at compressor. Now if the key is off you should have 12.6 at pigtail unless someone has hot wired it where it is live all the time
Old Oct 18, 2020 | 10:03 AM
marshal135's Avatar
marshal135
Have power or have not with key off? I didnt think the a.c. connector was continuously hot?
Thanks,
Marshal
To Voltage Drop @ AC compressor connection
